[GRASS-dev] Re: [GRASS GIS] #587: svn versions should better reflect svn rev
GRASS GIS trac at osgeo.org
Tue Dec 22 05:01:43 EST 2009
  Reporter:  hamish       |       Owner:  martinl
      Type:  enhancement  |      Status:  reopened
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  g.version
  Platform:  All          |         Cpu:  All
Comment (by martinl):
 Replying to [comment:31 hamish]:
 > I'd drop the --verbose option and just make the version number "solid".
 It's a neat trick, but the rev number is usually what you want to see and
 most folks won't discover the --v by chance.
 The default version formatting would not probably contain info about
 revision number, e.g. as used for manual page header. We could add new
 flag or just modify existing {{{-r}}} to print both revision numbers(?)
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/587#comment:32>
