[GRASS-dev] Re: [GRASS GIS] #587: svn versions should better
reflect svn rev
trac at osgeo.org
Tue Dec 22 09:23:49 EST 2009
#587: svn versions should better reflect svn rev
Reporter: hamish | Owner: martinl
Type: enhancement | Status: reopened
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.version
Platform: All | Cpu: All
Comment (by martinl):
Replying to [comment:33 hamish]:
> > The default version formatting would not probably contain info
> > about revision number,
> I disagree, when working with a SVN copy you always should know the
exact rev number you are dealing with. 6.5svn or 7.0svn both cover code
over years of development which represents completely different, well,
everything. Without the rev number the version data is mostly useless.
OK, probably you are right. Changed in r40111.
> > e.g. as used for manual page header.
> For things like help pages headers where you just want like "GRASS 6.4:
Raster Modules" you can always parse the string (or probably easier to
just hard code it..). For final releases all the extra noise is gone
anyway and replaced with simply ".z", so it isn't a problem there.
{{{g.version --q}}} currently prints only version number. Well, probably
it's not a good idea, verbose levels are used for progress information
which is not this case. What do you think?
Ticket URL: <http://trac.osgeo.org/grass/ticket/587#comment:34>
