[GRASS-dev] Re: [GRASS GIS] #788: r.out.gdal and nodata
Markus Metz
markus.metz.giswork at googlemail.com
Wed Dec 23 05:35:18 EST 2009
trac server gives problems, doesn't send new comment to list, see
https://trac.osgeo.org/grass/ticket/788#comment:7
> Reporter: frankie | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: normal | Milestone: 6.4.0
> Component: Raster | Version: 6.4.0 RCs
> Resolution: | Keywords: r.out.gdal, nodata
> Platform: Linux | Cpu: Unspecified
> Comment (by hamish):
> Ok sounds good. Lets go ahead and backport what's in the gr7 version to
> gr6.5. No point in widely testing dead-end code in 6.5...
> Replying to [comment:5 mmetz]:
> > The checks during the actual export could be moved to a
> > separate pass over all raster bands to be exported, I think
> > this is the safest solution, then r.out.gdal does not have to
> > bother with cleaning up and can leave all format-specific error
> > handling to GDAL.
> sounds ok to me/I could live with that. anyone else have a POV?
> > What is missing is a region check. At the very least, r.out.gdal
> > should make sure that at least some parts of the raster maps to
> > be exported fall within the current region, if not, abort with
> > error: raster map outside current region, nothing to export.
> hmmm. I would not do that, it is straying away from checking for errors
> into checking for intention. I would say that's a good idea but change it
> to a G_warning() or G_message() instead of G_fatal_error() and just write
> a map full of NULLs regardless. No other GRASS raster module refuses to go
> on if you have the region (ie '''WIND'''ow) set beyond its bounds.
> e.g. I have a script which tiles a raster into a series of small geotiffs.
> say I had a region with a full raster map in the top left and another in
> the bottom right with overlapping the corners in the middle and empty
> space in the opposite corners. I'd want those all-NULL tiles instead of a
> 404 error.
> Hamish
