[GRASS-dev] Re: [GRASS GIS] #845: r.proj[.seg]: new flag to show
reprojected bounds and exit
trac at osgeo.org
Wed Dec 23 20:34:48 EST 2009
#845: r.proj[.seg]: new flag to show reprojected bounds and exit
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: r.proj
Platform: All | Cpu: All
Comment (by hamish):
FWIW I'm not a fan of the r.in.gdal -e flag. If it were not for the
create-new-location ability I'd argue that it should be removed
(as only g.region should be changing the DEFAULT_WIND or region settings).
But because of the create-new-location r.in.gdal ability why avoid setting
the resolution in that case? (and make then make it automatic for new
location creation but remove the flag for general use)
r.in.xyz has a similar "issue", but there as well automatically doing the
wrong thing is not a good solution. You should have to ask it to do the
wrong thing.. :) It is worse for r.in.xyz because there is no starting
clue as to what the resolution should be.
You are not doing new users any favors by giving them a default which
produces bad results, when the path to real success is not very intuitive.
Very good guiding documentation or an interactive wizard is the solution
there.
For r.proj we have starting info and math on our side, so we have better
chances at guessing what the region and resolution will be.
Still, some rounds of 'g.region -p' + 'g.region res= -a' will be needed to
get it right. FWIW, note that my patch exports the bounds before they are
grown a few cells outwards by the following code.
I suggest we tackle the i.rectify bug before thinking about adding new
functionality to automatically set stuff.
see
* http://intevation.de/rt/webrt?serial_num=3296
* http://intevation.de/rt/webrt?serial_num=3052
2c,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/845#comment:2>
