[GRASS-dev] Re: [GRASS GIS] #848: v.in.mapgen: allow direct input from stdin
GRASS GIS trac at osgeo.org
Mon Dec 28 21:11:57 EST 2009
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Vector       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  v.in.mapgen
  Platform:  All          |         Cpu:  All
Changes (by hamish):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I've just added a new ''v.in.lines'' wrapper shell script into the svn
 addons repo.
 after suitable testing and porting to python it should be added into the
 main archive, as what it wraps (v.in.mapgen -f) is not at all obvious for
 the task.
 known bug/feature: if you specify a fs=[not whitespace] when there is
 really whitespace as the fs it will still work. shrug.
 intentional but subtle feature: if you pass 2D data to it and use the -z
 flag to make a 3D vector line the z coordinate will be populated with 0s.
 enjoy,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/848#comment:1>
