[GRASS-dev] [GRASS GIS] #849: command line completion and tips do not show up
GRASS GIS trac at osgeo.org
Thu Dec 31 10:57:09 EST 2009
 Reporter:  timmie       |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.5.0
Component:  wxGUI        |     Version:  svn-develbranch6
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 1) Grass waschecked out from SVN:
 https://svn.osgeo.org/grass/grass/branches/develbranch_6
 Revision: 40163
 2) Grass was configured with the following options:
 CFLAGS="-g -Wall" ./configure   \
 --with-cxx --with-freetype=yes   \
 --with-postgres=no \
 --with-sqlite=yes \
 --enable-largefile=yes \
 --with-tcltk-includes=/usr/include/tcl8.4 \
 --with-python=/usr/bin/python2.6-config \
 --with-wxwidgets=yes \
 --with-nls --enable-largefile \
 --with-proj-share=/usr/share/proj \
 --with-geos=yes  \
 --with-sqlite3=yes  \
 --with-ecw=yes \
 --with-readline
 3) then make was executed and sudo checkinstall was used to create &
 install the package
 4) then GRASS was run with grass65
 5) the commandline does not work: no TAB completion, no tooltips
Ticket URL: <http://trac.osgeo.org/grass/ticket/849>
