[GRASS-dev] GRASS 7 nviz (tcltk) no longer compiles on Mac
Michael Barton michael.barton at asu.edu
Sun Feb 1 01:55:30 EST 2009
Just did an update and compile from the SVN. The original TclTk
version of nviz will no longer compile on the Mac. I wonder if this is
related to the change to make it TclTk 8.6 compatible?
Anyway, I put the lengthy error into a text file and am attaching it.
Michael
cmb-MBP-2:nviz cmbarton$ make
make -C src
gcc -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.6.0/include  -arch i386 -Os     -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.6.0/include -I/Library/Frameworks/UnixImageIO.framework/unix/include  -I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers   -DPACKAGE=\"\"   -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/togl.o -c togl.c
In file included from togl.c:53:
/usr/include/tkMacOSX.h:19:19: error: tkInt.h: No such file or directory
In file included from /usr/include/tkMacOSX.h:32,
                 from togl.c:53:
/usr/include/tkPlatDecls.h:107: error: syntax error before ‘*’ token
/usr/include/tkPlatDecls.h:152: error: syntax error before ‘*’ token
togl.c:54:54: error: tkMacOSXInt.h: No such file or directory
togl.c:265: error: syntax error before ‘XVisualInfo’
togl.c:265: warning: no semicolon at end of struct or union
togl.c:271: error: syntax error before ‘}’ token
togl.c:310: error: invalid use of incomplete typedef ‘Togl’
togl.c:313: error: invalid use of incomplete typedef ‘Togl’
togl.c:316: error: invalid use of incomplete typedef ‘Togl’
togl.c:319: error: invalid use of incomplete typedef ‘Togl’
togl.c:322: error: invalid use of incomplete typedef ‘Togl’
togl.c:325: error: invalid use of incomplete typedef ‘Togl’
togl.c:328: error: invalid use of incomplete typedef ‘Togl’
togl.c:331: error: invalid use of incomplete typedef ‘Togl’
togl.c:334: error: invalid use of incomplete typedef ‘Togl’
togl.c:337: error: invalid use of incomplete typedef ‘Togl’
togl.c:340: error: invalid use of incomplete typedef ‘Togl’
togl.c:343: error: invalid use of incomplete typedef ‘Togl’
togl.c:347: error: invalid use of incomplete typedef ‘Togl’
togl.c:351: error: invalid use of incomplete typedef ‘Togl’
togl.c:355: error: invalid use of incomplete typedef ‘Togl’
togl.c:358: error: invalid use of incomplete typedef ‘Togl’
togl.c:361: error: invalid use of incomplete typedef ‘Togl’
togl.c:364: error: invalid use of incomplete typedef ‘Togl’
togl.c:367: error: invalid use of incomplete typedef ‘Togl’
togl.c:370: error: invalid use of incomplete typedef ‘Togl’
togl.c:373: error: invalid use of incomplete typedef ‘Togl’
togl.c:376: error: invalid use of incomplete typedef ‘Togl’
togl.c:379: error: invalid use of incomplete typedef ‘Togl’
togl.c:388: error: invalid use of incomplete typedef ‘Togl’
togl.c:392: error: invalid use of incomplete typedef ‘Togl’
togl.c:395: error: invalid use of incomplete typedef ‘Togl’
togl.c:398: error: invalid use of incomplete typedef ‘Togl’
togl.c:401: error: invalid use of incomplete typedef ‘Togl’
togl.c:404: error: invalid use of incomplete typedef ‘Togl’
togl.c:407: error: invalid use of incomplete typedef ‘Togl’
togl.c: In function ‘AddToList’:
togl.c:437: error: dereferencing pointer to incomplete type
togl.c:437: error: request for member ‘Next’ in something not a structure or union
togl.c: In function ‘RemoveFromList’:
togl.c:453: error: dereferencing pointer to incomplete type
togl.c:453: error: request for member ‘Next’ in something not a structure or union
togl.c:455: error: dereferencing pointer to incomplete type
togl.c:455: error: request for member ‘Next’ in something not a structure or union
togl.c:460: error: dereferencing pointer to incomplete type
togl.c:460: error: request for member ‘Next’ in something not a structure or union
togl.c: In function ‘FindTogl’:
togl.c:473: error: dereferencing pointer to incomplete type
togl.c:473: error: request for member ‘Ident’ in something not a structure or union
togl.c:473: warning: passing argument 1 of ‘strcmp’ from incompatible pointer type
togl.c:475: error: dereferencing pointer to incomplete type
togl.c:475: error: request for member ‘Next’ in something not a structure or union
togl.c: In function ‘Togl_SetCreateFunc’:
togl.c:917: error: dereferencing pointer to incomplete type
togl.c:917: error: request for member ‘CreateProc’ in something not a structure or union
togl.c: In function ‘Togl_SetDisplayFunc’:
togl.c:927: error: dereferencing pointer to incomplete type
togl.c:927: error: request for member ‘DisplayProc’ in something not a structure or union
togl.c: In function ‘Togl_SetReshapeFunc’:
togl.c:937: error: dereferencing pointer to incomplete type
togl.c:937: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c: In function ‘Togl_SetDestroyFunc’:
togl.c:947: error: dereferencing pointer to incomplete type
togl.c:947: error: request for member ‘DestroyProc’ in something not a structure or union
togl.c: In function ‘Togl_Timer’:
togl.c:961: error: dereferencing pointer to incomplete type
togl.c:961: error: request for member ‘TimerProc’ in something not a structure or union
togl.c:962: error: dereferencing pointer to incomplete type
togl.c:962: error: request for member ‘TimerProc’ in something not a structure or union
togl.c:962: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:968: error: dereferencing pointer to incomplete type
togl.c:968: error: request for member ‘timerHandler’ in something not a structure or union
togl.c:969: error: dereferencing pointer to incomplete type
togl.c:969: error: request for member ‘TimerInterval’ in something not a structure or union
togl.c:970: warning: passing argument 1 of ‘Tcl_CreateTimerHandler’ makes integer from pointer without a cast
togl.c: In function ‘Togl_SetTimerFunc’:
togl.c:987: error: dereferencing pointer to incomplete type
togl.c:987: error: request for member ‘TimerProc’ in something not a structure or union
togl.c:990: error: dereferencing pointer to incomplete type
togl.c:990: error: request for member ‘timerHandler’ in something not a structure or union
togl.c:991: error: dereferencing pointer to incomplete type
togl.c:991: error: request for member ‘TimerInterval’ in something not a structure or union
togl.c:992: warning: passing argument 1 of ‘Tcl_CreateTimerHandler’ makes integer from pointer without a cast
togl.c: In function ‘Togl_MakeCurrent’:
togl.c:1048: error: dereferencing pointer to incomplete type
togl.c:1048: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1050: error: dereferencing pointer to incomplete type
togl.c:1050: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1050: warning: passing argument 1 of ‘aglSetCurrentContext’ from incompatible pointer type
togl.c: In function ‘SetMacBufRect’:
togl.c:1082: error: dereferencing pointer to incomplete type
togl.c:1082: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1082: error: ‘struct Tk_ConfigSpec’ has no member named ‘changes’
togl.c:1082: error: request for member ‘width’ in something not a structure or union
togl.c:1083: error: dereferencing pointer to incomplete type
togl.c:1083: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1083: error: ‘struct Tk_ConfigSpec’ has no member named ‘changes’
togl.c:1083: error: request for member ‘height’ in something not a structure or union
togl.c:1084: error: ‘TkWindow’ undeclared (first use in this function)
togl.c:1084: error: (Each undeclared identifier is reported only once
togl.c:1084: error: for each function it appears in.)
togl.c:1084: error: syntax error before ‘)’ token
togl.c:1084: error: dereferencing pointer to incomplete type
togl.c:1084: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1084: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1084: error: ‘struct Tk_ConfigSpec’ has no member named ‘privatePtr’
togl.c:1084: error: ‘struct Tk_ConfigSpec’ has no member named ‘xOff’
togl.c:1088: warning: ‘GetPortBounds’ is deprecated (declared at /System/Library/Frameworks/ApplicationServices.framework/Frameworks/QD.framework/Headers/QuickdrawAPI.h:4457)
togl.c:1088: error: syntax error before ‘)’ token
togl.c:1088: error: dereferencing pointer to incomplete type
togl.c:1088: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1088: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1088: error: ‘struct Tk_ConfigSpec’ has no member named ‘privatePtr’
togl.c:1088: error: ‘struct Tk_ConfigSpec’ has no member named ‘toplevel’
togl.c:1088: error: ‘struct Tk_ConfigSpec’ has no member named ‘grafPtr’
togl.c:1089: warning: passing argument 1 of ‘GetPortBounds’ from incompatible pointer type
togl.c:1092: error: syntax error before ‘)’ token
togl.c:1092: error: dereferencing pointer to incomplete type
togl.c:1092: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1092: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1092: error: ‘struct Tk_ConfigSpec’ has no member named ‘privatePtr’
togl.c:1092: error: ‘struct Tk_ConfigSpec’ has no member named ‘yOff’
togl.c:1092: error: invalid operands to binary -
togl.c:1094: error: dereferencing pointer to incomplete type
togl.c:1094: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1094: warning: passing argument 1 of ‘aglSetInteger’ from incompatible pointer type
togl.c:1095: error: dereferencing pointer to incomplete type
togl.c:1095: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1095: warning: passing argument 1 of ‘aglEnable’ from incompatible pointer type
togl.c:1096: error: dereferencing pointer to incomplete type
togl.c:1096: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1096: warning: passing argument 1 of ‘aglUpdateContext’ from incompatible pointer type
togl.c: In function ‘Togl_Render’:
togl.c:1112: error: dereferencing pointer to incomplete type
togl.c:1112: error: request for member ‘DisplayProc’ in something not a structure or union
togl.c:1161: error: dereferencing pointer to incomplete type
togl.c:1161: error: request for member ‘DisplayProc’ in something not a structure or union
togl.c:1161: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1174: error: dereferencing pointer to incomplete type
togl.c:1174: error: request for member ‘UpdatePending’ in something not a structure or union
togl.c: In function ‘RenderOverlay’:
togl.c:1183: error: dereferencing pointer to incomplete type
togl.c:1183: error: request for member ‘OverlayFlag’ in something not a structure or union
togl.c:1183: error: request for member ‘OverlayDisplayProc’ in something not a structure or union
togl.c:1202: error: dereferencing pointer to incomplete type
togl.c:1202: error: request for member ‘OverlayDisplayProc’ in something not a structure or union
togl.c:1202: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1204: error: dereferencing pointer to incomplete type
togl.c:1204: error: request for member ‘OverlayUpdatePending’ in something not a structure or union
togl.c: In function ‘Togl_Configure’:
togl.c:1216: error: dereferencing pointer to incomplete type
togl.c:1216: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:1217: error: dereferencing pointer to incomplete type
togl.c:1217: error: request for member ‘RgbaRed’ in something not a structure or union
togl.c:1218: error: dereferencing pointer to incomplete type
togl.c:1218: error: request for member ‘RgbaGreen’ in something not a structure or union
togl.c:1219: error: dereferencing pointer to incomplete type
togl.c:1219: error: request for member ‘RgbaBlue’ in something not a structure or union
togl.c:1220: error: dereferencing pointer to incomplete type
togl.c:1220: error: request for member ‘DoubleFlag’ in something not a structure or union
togl.c:1221: error: dereferencing pointer to incomplete type
togl.c:1221: error: request for member ‘DepthFlag’ in something not a structure or union
togl.c:1222: error: dereferencing pointer to incomplete type
togl.c:1222: error: request for member ‘DepthSize’ in something not a structure or union
togl.c:1223: error: dereferencing pointer to incomplete type
togl.c:1223: error: request for member ‘AccumFlag’ in something not a structure or union
togl.c:1224: error: dereferencing pointer to incomplete type
togl.c:1224: error: request for member ‘AccumRed’ in something not a structure or union
togl.c:1225: error: dereferencing pointer to incomplete type
togl.c:1225: error: request for member ‘AccumGreen’ in something not a structure or union
togl.c:1226: error: dereferencing pointer to incomplete type
togl.c:1226: error: request for member ‘AccumBlue’ in something not a structure or union
togl.c:1227: error: dereferencing pointer to incomplete type
togl.c:1227: error: request for member ‘AccumAlpha’ in something not a structure or union
togl.c:1228: error: dereferencing pointer to incomplete type
togl.c:1228: error: request for member ‘AlphaFlag’ in something not a structure or union
togl.c:1229: error: dereferencing pointer to incomplete type
togl.c:1229: error: request for member ‘AlphaSize’ in something not a structure or union
togl.c:1230: error: dereferencing pointer to incomplete type
togl.c:1230: error: request for member ‘StencilFlag’ in something not a structure or union
togl.c:1231: error: dereferencing pointer to incomplete type
togl.c:1231: error: request for member ‘StencilSize’ in something not a structure or union
togl.c:1232: error: dereferencing pointer to incomplete type
togl.c:1232: error: request for member ‘AuxNumber’ in something not a structure or union
togl.c:1233: error: dereferencing pointer to incomplete type
togl.c:1233: error: request for member ‘Width’ in something not a structure or union
togl.c:1234: error: dereferencing pointer to incomplete type
togl.c:1234: error: request for member ‘Height’ in something not a structure or union
togl.c:1235: error: dereferencing pointer to incomplete type
togl.c:1235: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:1237: error: dereferencing pointer to incomplete type
togl.c:1237: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1238: warning: passing argument 2 of ‘Tk_ConfigureWidget’ from incompatible pointer type
togl.c:1242: error: dereferencing pointer to incomplete type
togl.c:1242: error: request for member ‘OverlayFlag’ in something not a structure or union
togl.c:1248: error: dereferencing pointer to incomplete type
togl.c:1248: error: request for member ‘Width’ in something not a structure or union
togl.c:1248: warning: comparison between pointer and integer
togl.c:1248: error: request for member ‘Height’ in something not a structure or union
togl.c:1249: warning: comparison between pointer and integer
togl.c:1249: error: dereferencing pointer to incomplete type
togl.c:1249: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:1252: error: dereferencing pointer to incomplete type
togl.c:1252: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1252: error: request for member ‘Width’ in something not a structure or union
togl.c:1252: error: request for member ‘Height’ in something not a structure or union
togl.c:1252: warning: passing argument 1 of ‘Tk_ResizeWindow’ from incompatible pointer type
togl.c:1252: warning: passing argument 2 of ‘Tk_ResizeWindow’ makes integer from pointer without a cast
togl.c:1252: warning: passing argument 3 of ‘Tk_ResizeWindow’ makes integer from pointer without a cast
togl.c:1254: error: dereferencing pointer to incomplete type
togl.c:1254: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c:1260: error: dereferencing pointer to incomplete type
togl.c:1260: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1264: error: dereferencing pointer to incomplete type
togl.c:1264: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c:1264: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1268: error: dereferencing pointer to incomplete type
togl.c:1268: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:1269: warning: comparison between pointer and integer
togl.c:1269: error: dereferencing pointer to incomplete type
togl.c:1269: error: request for member ‘RgbaRed’ in something not a structure or union
togl.c:1270: warning: comparison between pointer and integer
togl.c:1270: error: dereferencing pointer to incomplete type
togl.c:1270: error: request for member ‘RgbaGreen’ in something not a structure or union
togl.c:1271: warning: comparison between pointer and integer
togl.c:1271: error: dereferencing pointer to incomplete type
togl.c:1271: error: request for member ‘RgbaBlue’ in something not a structure or union
togl.c:1272: warning: comparison between pointer and integer
togl.c:1272: error: dereferencing pointer to incomplete type
togl.c:1272: error: request for member ‘DoubleFlag’ in something not a structure or union
togl.c:1273: warning: comparison between pointer and integer
togl.c:1273: error: dereferencing pointer to incomplete type
togl.c:1273: error: request for member ‘DepthFlag’ in something not a structure or union
togl.c:1274: warning: comparison between pointer and integer
togl.c:1274: error: dereferencing pointer to incomplete type
togl.c:1274: error: request for member ‘DepthSize’ in something not a structure or union
togl.c:1275: warning: comparison between pointer and integer
togl.c:1275: error: dereferencing pointer to incomplete type
togl.c:1275: error: request for member ‘AccumFlag’ in something not a structure or union
togl.c:1276: warning: comparison between pointer and integer
togl.c:1276: error: dereferencing pointer to incomplete type
togl.c:1276: error: request for member ‘AccumRed’ in something not a structure or union
togl.c:1277: warning: comparison between pointer and integer
togl.c:1277: error: dereferencing pointer to incomplete type
togl.c:1277: error: request for member ‘AccumGreen’ in something not a structure or union
togl.c:1278: warning: comparison between pointer and integer
togl.c:1278: error: dereferencing pointer to incomplete type
togl.c:1278: error: request for member ‘AccumBlue’ in something not a structure or union
togl.c:1279: warning: comparison between pointer and integer
togl.c:1279: error: dereferencing pointer to incomplete type
togl.c:1279: error: request for member ‘AccumAlpha’ in something not a structure or union
togl.c:1280: warning: comparison between pointer and integer
togl.c:1280: error: dereferencing pointer to incomplete type
togl.c:1280: error: request for member ‘AlphaFlag’ in something not a structure or union
togl.c:1281: warning: comparison between pointer and integer
togl.c:1281: error: dereferencing pointer to incomplete type
togl.c:1281: error: request for member ‘AlphaSize’ in something not a structure or union
togl.c:1282: warning: comparison between pointer and integer
togl.c:1282: error: dereferencing pointer to incomplete type
togl.c:1282: error: request for member ‘StencilFlag’ in something not a structure or union
togl.c:1283: warning: comparison between pointer and integer
togl.c:1283: error: dereferencing pointer to incomplete type
togl.c:1283: error: request for member ‘StencilSize’ in something not a structure or union
togl.c:1284: warning: comparison between pointer and integer
togl.c:1284: error: dereferencing pointer to incomplete type
togl.c:1284: error: request for member ‘AuxNumber’ in something not a structure or union
togl.c: In function ‘Togl_Widget’:
togl.c:1319: error: dereferencing pointer to incomplete type
togl.c:1319: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1320: warning: passing argument 2 of ‘Tk_ConfigureInfo’ from incompatible pointer type
togl.c:1331: error: dereferencing pointer to incomplete type
togl.c:1331: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1332: warning: passing argument 2 of ‘Tk_ConfigureInfo’ from incompatible pointer type
togl.c: In function ‘Togl_Cmd’:
togl.c:1437: error: invalid application of ‘sizeof’ to incomplete type ‘Togl’
togl.c:1442: error: dereferencing pointer to incomplete type
togl.c:1442: error: request for member ‘Next’ in something not a structure or union
togl.c:1450: error: dereferencing pointer to incomplete type
togl.c:1450: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1452: error: dereferencing pointer to incomplete type
togl.c:1452: error: request for member ‘display’ in something not a structure or union
togl.c:1453: error: dereferencing pointer to incomplete type
togl.c:1453: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1454: error: dereferencing pointer to incomplete type
togl.c:1454: error: request for member ‘Interp’ in something not a structure or union
togl.c:1456: error: dereferencing pointer to incomplete type
togl.c:1456: error: request for member ‘Cursor’ in something not a structure or union
togl.c:1458: error: dereferencing pointer to incomplete type
togl.c:1458: error: request for member ‘Width’ in something not a structure or union
togl.c:1459: error: dereferencing pointer to incomplete type
togl.c:1459: error: request for member ‘Height’ in something not a structure or union
togl.c:1460: error: dereferencing pointer to incomplete type
togl.c:1460: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:1461: error: dereferencing pointer to incomplete type
togl.c:1461: error: request for member ‘TimerInterval’ in something not a structure or union
togl.c:1462: error: dereferencing pointer to incomplete type
togl.c:1462: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:1463: error: dereferencing pointer to incomplete type
togl.c:1463: error: request for member ‘RgbaRed’ in something not a structure or union
togl.c:1464: error: dereferencing pointer to incomplete type
togl.c:1464: error: request for member ‘RgbaGreen’ in something not a structure or union
togl.c:1465: error: dereferencing pointer to incomplete type
togl.c:1465: error: request for member ‘RgbaBlue’ in something not a structure or union
togl.c:1466: error: dereferencing pointer to incomplete type
togl.c:1466: error: request for member ‘DoubleFlag’ in something not a structure or union
togl.c:1467: error: dereferencing pointer to incomplete type
togl.c:1467: error: request for member ‘DepthFlag’ in something not a structure or union
togl.c:1468: error: dereferencing pointer to incomplete type
togl.c:1468: error: request for member ‘DepthSize’ in something not a structure or union
togl.c:1469: error: dereferencing pointer to incomplete type
togl.c:1469: error: request for member ‘AccumFlag’ in something not a structure or union
togl.c:1470: error: dereferencing pointer to incomplete type
togl.c:1470: error: request for member ‘AccumRed’ in something not a structure or union
togl.c:1471: error: dereferencing pointer to incomplete type
togl.c:1471: error: request for member ‘AccumGreen’ in something not a structure or union
togl.c:1472: error: dereferencing pointer to incomplete type
togl.c:1472: error: request for member ‘AccumBlue’ in something not a structure or union
togl.c:1473: error: dereferencing pointer to incomplete type
togl.c:1473: error: request for member ‘AccumAlpha’ in something not a structure or union
togl.c:1474: error: dereferencing pointer to incomplete type
togl.c:1474: error: request for member ‘AlphaFlag’ in something not a structure or union
togl.c:1475: error: dereferencing pointer to incomplete type
togl.c:1475: error: request for member ‘AlphaSize’ in something not a structure or union
togl.c:1476: error: dereferencing pointer to incomplete type
togl.c:1476: error: request for member ‘StencilFlag’ in something not a structure or union
togl.c:1477: error: dereferencing pointer to incomplete type
togl.c:1477: error: request for member ‘StencilSize’ in something not a structure or union
togl.c:1478: error: dereferencing pointer to incomplete type
togl.c:1478: error: request for member ‘OverlayFlag’ in something not a structure or union
togl.c:1479: error: dereferencing pointer to incomplete type
togl.c:1479: error: request for member ‘StereoFlag’ in something not a structure or union
togl.c:1483: error: dereferencing pointer to incomplete type
togl.c:1483: error: request for member ‘AuxNumber’ in something not a structure or union
togl.c:1484: error: dereferencing pointer to incomplete type
togl.c:1484: error: request for member ‘Indirect’ in something not a structure or union
togl.c:1485: error: dereferencing pointer to incomplete type
togl.c:1485: error: request for member ‘PixelFormat’ in something not a structure or union
togl.c:1486: error: dereferencing pointer to incomplete type
togl.c:1486: error: request for member ‘UpdatePending’ in something not a structure or union
togl.c:1487: error: dereferencing pointer to incomplete type
togl.c:1487: error: request for member ‘OverlayUpdatePending’ in something not a structure or union
togl.c:1488: error: dereferencing pointer to incomplete type
togl.c:1488: error: request for member ‘CreateProc’ in something not a structure or union
togl.c:1489: error: dereferencing pointer to incomplete type
togl.c:1489: error: request for member ‘DisplayProc’ in something not a structure or union
togl.c:1490: error: dereferencing pointer to incomplete type
togl.c:1490: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c:1491: error: dereferencing pointer to incomplete type
togl.c:1491: error: request for member ‘DestroyProc’ in something not a structure or union
togl.c:1492: error: dereferencing pointer to incomplete type
togl.c:1492: error: request for member ‘TimerProc’ in something not a structure or union
togl.c:1493: error: dereferencing pointer to incomplete type
togl.c:1493: error: request for member ‘OverlayDisplayProc’ in something not a structure or union
togl.c:1494: error: dereferencing pointer to incomplete type
togl.c:1494: error: request for member ‘ShareList’ in something not a structure or union
togl.c:1495: error: dereferencing pointer to incomplete type
togl.c:1495: error: request for member ‘ShareContext’ in something not a structure or union
togl.c:1496: error: dereferencing pointer to incomplete type
togl.c:1496: error: request for member ‘Ident’ in something not a structure or union
togl.c:1497: error: dereferencing pointer to incomplete type
togl.c:1497: error: request for member ‘Client_Data’ in something not a structure or union
togl.c:1500: error: dereferencing pointer to incomplete type
togl.c:1500: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:1500: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:1500: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c:1501: error: dereferencing pointer to incomplete type
togl.c:1501: error: request for member ‘EpsMapSize’ in something not a structure or union
togl.c:1504: error: dereferencing pointer to incomplete type
togl.c:1504: error: request for member ‘widgetCmd’ in something not a structure or union
togl.c:1526: error: dereferencing pointer to incomplete type
togl.c:1526: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1526: warning: passing argument 1 of ‘SetClassProcsPtr’ from incompatible pointer type
togl.c:1534: error: dereferencing pointer to incomplete type
togl.c:1534: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1566: error: dereferencing pointer to incomplete type
togl.c:1566: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:1569: error: dereferencing pointer to incomplete type
togl.c:1569: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1569: warning: passing argument 1 of ‘Tk_MakeWindowExist’ from incompatible pointer type
togl.c:1570: error: dereferencing pointer to incomplete type
togl.c:1570: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1570: error: ‘struct Tk_ConfigSpec’ has no member named ‘window’
togl.c:1570: warning: comparison between pointer and integer
togl.c:1577: error: dereferencing pointer to incomplete type
togl.c:1577: error: request for member ‘CreateProc’ in something not a structure or union
togl.c:1578: error: dereferencing pointer to incomplete type
togl.c:1578: error: request for member ‘CreateProc’ in something not a structure or union
togl.c:1578: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1582: error: dereferencing pointer to incomplete type
togl.c:1582: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c:1583: error: dereferencing pointer to incomplete type
togl.c:1583: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c:1583: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:1587: error: dereferencing pointer to incomplete type
togl.c:1587: error: request for member ‘TimerProc’ in something not a structure or union
togl.c:1588: error: dereferencing pointer to incomplete type
togl.c:1588: error: request for member ‘TimerInterval’ in something not a structure or union
togl.c:1589: warning: passing argument 1 of ‘Tcl_CreateTimerHandler’ makes integer from pointer without a cast
togl.c: In function ‘Togl_CreateWindow’:
togl.c:1764: error: ‘XVisualInfo’ undeclared (first use in this function)
togl.c:1764: error: ‘visinfo’ undeclared (first use in this function)
togl.c:1764: error: invalid operands to binary *
togl.c:1795: error: syntax error before ‘VisInf’
togl.c:1799: error: dereferencing pointer to incomplete type
togl.c:1799: error: request for member ‘TkWin’ in something not a structure or union
togl.c:1799: error: ‘struct Tk_ConfigSpec’ has no member named ‘display’
togl.c:2092: error: dereferencing pointer to incomplete type
togl.c:2092: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2092: error: ‘struct Tk_ConfigSpec’ has no member named ‘screenNum’
togl.c:2093: error: dereferencing pointer to incomplete type
togl.c:2093: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:2117: error: dereferencing pointer to incomplete type
togl.c:2117: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:2118: error: dereferencing pointer to incomplete type
togl.c:2118: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:2119: error: dereferencing pointer to incomplete type
togl.c:2119: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:2120: error: dereferencing pointer to incomplete type
togl.c:2120: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:2121: error: dereferencing pointer to incomplete type
togl.c:2121: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c:2122: error: dereferencing pointer to incomplete type
togl.c:2122: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c:2123: error: dereferencing pointer to incomplete type
togl.c:2123: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:2123: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:2123: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c:2124: error: dereferencing pointer to incomplete type
togl.c:2124: error: request for member ‘EpsMapSize’ in something not a structure or union
togl.c:2134: error: dereferencing pointer to incomplete type
togl.c:2134: error: request for member ‘PrivateCmapFlag’ in something not a structure or union
togl.c:2146: error: ‘struct Tk_ConfigSpec’ has no member named ‘visual’
togl.c:2146: warning: comparison of distinct pointer types lacks a cast
togl.c:2148: error: dereferencing pointer to incomplete type
togl.c:2148: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2148: error: ‘struct Tk_ConfigSpec’ has no member named ‘atts’
togl.c:2148: error: request for member ‘colormap’ in something not a structure or union
togl.c:2151: error: ‘struct Tk_ConfigSpec’ has no member named ‘screen’
togl.c:2151: warning: passing argument 2 of ‘XRootWindow’ makes integer from pointer without a cast
togl.c:2152: error: ‘struct Tk_ConfigSpec’ has no member named ‘visual’
togl.c:2152: warning: passing argument 3 of ‘XCreateColormap’ from incompatible pointer type
togl.c:2187: error: ‘TkWindow’ undeclared (first use in this function)
togl.c:2187: error: ‘winPtr’ undeclared (first use in this function)
togl.c:2187: error: invalid operands to binary *
togl.c:2187: error: syntax error before ‘)’ token
togl.c:2206: error: dereferencing pointer to incomplete type
togl.c:2206: error: request for member ‘ShareContext’ in something not a structure or union
togl.c:2206: warning: passing argument 1 of ‘FindTogl’ from incompatible pointer type
togl.c:2208: error: dereferencing pointer to incomplete type
togl.c:2208: error: request for member ‘ShareContext’ in something not a structure or union
togl.c:2208: warning: passing argument 1 of ‘FindTogl’ from incompatible pointer type
togl.c:2211: error: dereferencing pointer to incomplete type
togl.c:2211: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2212: error: dereferencing pointer to incomplete type
togl.c:2212: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2213: error: dereferencing pointer to incomplete type
togl.c:2213: error: request for member ‘VisInfo’ in something not a structure or union
togl.c:2214: error: dereferencing pointer to incomplete type
togl.c:2214: error: request for member ‘VisInfo’ in something not a structure or union
togl.c:2219: error: dereferencing pointer to incomplete type
togl.c:2219: error: request for member ‘PixelFormat’ in something not a structure or union
togl.c:2221: error: dereferencing pointer to incomplete type
togl.c:2221: error: request for member ‘PixelFormat’ in something not a structure or union
togl.c:2228: error: dereferencing pointer to incomplete type
togl.c:2228: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:2229: error: dereferencing pointer to incomplete type
togl.c:2229: error: request for member ‘DoubleFlag’ in something not a structure or union
togl.c:2230: error: dereferencing pointer to incomplete type
togl.c:2230: error: request for member ‘StereoFlag’ in something not a structure or union
togl.c:2232: error: dereferencing pointer to incomplete type
togl.c:2232: error: request for member ‘Interp’ in something not a structure or union
togl.c:2235: warning: passing argument 1 of ‘Tcl_SetResult’ from incompatible pointer type
togl.c:2245: error: dereferencing pointer to incomplete type
togl.c:2245: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:2249: error: dereferencing pointer to incomplete type
togl.c:2249: error: request for member ‘RgbaRed’ in something not a structure or union
togl.c:2251: error: dereferencing pointer to incomplete type
togl.c:2251: error: request for member ‘RgbaGreen’ in something not a structure or union
togl.c:2253: error: dereferencing pointer to incomplete type
togl.c:2253: error: request for member ‘RgbaBlue’ in something not a structure or union
togl.c:2254: error: dereferencing pointer to incomplete type
togl.c:2254: error: request for member ‘AlphaFlag’ in something not a structure or union
togl.c:2256: error: dereferencing pointer to incomplete type
togl.c:2256: error: request for member ‘AlphaSize’ in something not a structure or union
togl.c:2263: error: dereferencing pointer to incomplete type
togl.c:2263: error: request for member ‘DepthFlag’ in something not a structure or union
togl.c:2265: error: dereferencing pointer to incomplete type
togl.c:2265: error: request for member ‘DepthSize’ in something not a structure or union
togl.c:2267: error: dereferencing pointer to incomplete type
togl.c:2267: error: request for member ‘DoubleFlag’ in something not a structure or union
togl.c:2270: error: dereferencing pointer to incomplete type
togl.c:2270: error: request for member ‘StencilFlag’ in something not a structure or union
togl.c:2272: error: dereferencing pointer to incomplete type
togl.c:2272: error: request for member ‘StencilSize’ in something not a structure or union
togl.c:2274: error: dereferencing pointer to incomplete type
togl.c:2274: error: request for member ‘AccumFlag’ in something not a structure or union
togl.c:2276: error: dereferencing pointer to incomplete type
togl.c:2276: error: request for member ‘AccumRed’ in something not a structure or union
togl.c:2278: error: dereferencing pointer to incomplete type
togl.c:2278: error: request for member ‘AccumGreen’ in something not a structure or union
togl.c:2280: error: dereferencing pointer to incomplete type
togl.c:2280: error: request for member ‘AccumBlue’ in something not a structure or union
togl.c:2281: error: dereferencing pointer to incomplete type
togl.c:2281: error: request for member ‘AlphaFlag’ in something not a structure or union
togl.c:2283: error: dereferencing pointer to incomplete type
togl.c:2283: error: request for member ‘AccumAlpha’ in something not a structure or union
togl.c:2286: error: dereferencing pointer to incomplete type
togl.c:2286: error: request for member ‘AuxNumber’ in something not a structure or union
togl.c:2288: error: dereferencing pointer to incomplete type
togl.c:2288: error: request for member ‘AuxNumber’ in something not a structure or union
togl.c:2293: error: dereferencing pointer to incomplete type
togl.c:2293: error: request for member ‘Interp’ in something not a structure or union
togl.c:2295: warning: passing argument 1 of ‘Tcl_SetResult’ from incompatible pointer type
togl.c:2303: error: dereferencing pointer to incomplete type
togl.c:2303: error: request for member ‘ShareList’ in something not a structure or union
togl.c:2305: error: dereferencing pointer to incomplete type
togl.c:2305: error: request for member ‘ShareList’ in something not a structure or union
togl.c:2305: warning: passing argument 1 of ‘FindTogl’ from incompatible pointer type
togl.c:2308: error: dereferencing pointer to incomplete type
togl.c:2308: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2310: error: dereferencing pointer to incomplete type
togl.c:2310: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2315: error: dereferencing pointer to incomplete type
togl.c:2315: error: request for member ‘Interp’ in something not a structure or union
togl.c:2318: warning: passing argument 1 of ‘Tcl_SetResult’ from incompatible pointer type
togl.c:2320: error: dereferencing pointer to incomplete type
togl.c:2320: error: request for member ‘Interp’ in something not a structure or union
togl.c:2323: warning: passing argument 1 of ‘Tcl_SetResult’ from incompatible pointer type
togl.c:2325: error: dereferencing pointer to incomplete type
togl.c:2325: error: request for member ‘Interp’ in something not a structure or union
togl.c:2328: warning: passing argument 1 of ‘Tcl_SetResult’ from incompatible pointer type
togl.c:2330: error: dereferencing pointer to incomplete type
togl.c:2330: error: request for member ‘Interp’ in something not a structure or union
togl.c:2333: warning: passing argument 1 of ‘Tcl_SetResult’ from incompatible pointer type
togl.c:2338: warning: ‘aglSetDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:322)
togl.c:2338: error: dereferencing pointer to incomplete type
togl.c:2338: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2340: error: ‘MacDrawable’ undeclared (first use in this function)
togl.c:2340: error: syntax error before ‘)’ token
togl.c:2340: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:2340: error: ‘struct Tk_ConfigSpec’ has no member named ‘toplevel’
togl.c:2340: error: ‘struct Tk_ConfigSpec’ has no member named ‘grafPtr’
togl.c:2344: warning: passing argument 1 of ‘aglSetDrawable’ from incompatible pointer type
togl.c:2344: warning: passing argument 2 of ‘aglSetDrawable’ from incompatible pointer type
togl.c:2345: error: dereferencing pointer to incomplete type
togl.c:2345: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2345: warning: passing argument 1 of ‘aglDestroyContext’ from incompatible pointer type
togl.c:2346: error: dereferencing pointer to incomplete type
togl.c:2346: error: request for member ‘Interp’ in something not a structure or union
togl.c:2347: warning: passing argument 1 of ‘Tcl_SetResult’ from incompatible pointer type
togl.c:2352: error: ‘VisInf’ undeclared (first use in this function)
togl.c:2353: error: ‘struct Tk_ConfigSpec’ has no member named ‘visual’
togl.c:2354: error: ‘struct Tk_ConfigSpec’ has no member named ‘depth’
togl.c:2354: error: ‘struct Tk_ConfigSpec’ has no member named ‘visual’
togl.c:2354: error: ‘struct Tk_ConfigSpec’ has no member named ‘bits_per_rgb’
togl.c:2356: error: dereferencing pointer to incomplete type
togl.c:2356: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2356: error: ‘struct Tk_ConfigSpec’ has no member named ‘visual’
togl.c:2356: error: ‘struct Tk_ConfigSpec’ has no member named ‘depth’
togl.c:2356: warning: passing argument 1 of ‘Tk_SetWindowVisual’ from incompatible pointer type
togl.c:2356: warning: passing argument 2 of ‘Tk_SetWindowVisual’ from incompatible pointer type
togl.c:2356: warning: passing argument 3 of ‘Tk_SetWindowVisual’ makes integer from pointer without a cast
togl.c:2377: error: dereferencing pointer to incomplete type
togl.c:2377: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:2388: error: dereferencing pointer to incomplete type
togl.c:2388: error: request for member ‘EpsMapSize’ in something not a structure or union
togl.c:2388: warning: comparison between pointer and integer
togl.c:2389: error: dereferencing pointer to incomplete type
togl.c:2389: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:2390: error: dereferencing pointer to incomplete type
togl.c:2390: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:2391: error: dereferencing pointer to incomplete type
togl.c:2391: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:2392: error: dereferencing pointer to incomplete type
togl.c:2392: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:2393: error: dereferencing pointer to incomplete type
togl.c:2393: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c:2394: error: dereferencing pointer to incomplete type
togl.c:2394: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c:2395: error: dereferencing pointer to incomplete type
togl.c:2395: error: request for member ‘EpsMapSize’ in something not a structure or union
togl.c:2396: error: dereferencing pointer to incomplete type
togl.c:2396: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:2397: error: dereferencing pointer to incomplete type
togl.c:2397: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:2399: error: dereferencing pointer to incomplete type
togl.c:2399: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c: In function ‘Togl_WorldChanged’:
togl.c:2416: error: dereferencing pointer to incomplete type
togl.c:2416: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2416: error: request for member ‘Width’ in something not a structure or union
togl.c:2416: error: request for member ‘Height’ in something not a structure or union
togl.c:2416: warning: passing argument 1 of ‘Tk_GeometryRequest’ from incompatible pointer type
togl.c:2416: warning: passing argument 2 of ‘Tk_GeometryRequest’ makes integer from pointer without a cast
togl.c:2416: warning: passing argument 3 of ‘Tk_GeometryRequest’ makes integer from pointer without a cast
togl.c:2417: error: dereferencing pointer to incomplete type
togl.c:2417: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2417: warning: passing argument 1 of ‘Tk_SetInternalBorder’ from incompatible pointer type
togl.c:2418: error: dereferencing pointer to incomplete type
togl.c:2418: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:2419: error: dereferencing pointer to incomplete type
togl.c:2419: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2419: error: request for member ‘Width’ in something not a structure or union
togl.c:2419: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:2419: error: invalid operands to binary /
togl.c:2420: error: dereferencing pointer to incomplete type
togl.c:2420: error: request for member ‘Height’ in something not a structure or union
togl.c:2420: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:2420: error: invalid operands to binary /
togl.c:2420: warning: passing argument 1 of ‘Tk_SetGrid’ from incompatible pointer type
togl.c:2420: warning: passing argument 2 of ‘Tk_SetGrid’ makes integer from pointer without a cast
togl.c:2420: warning: passing argument 3 of ‘Tk_SetGrid’ makes integer from pointer without a cast
togl.c:2420: warning: passing argument 4 of ‘Tk_SetGrid’ makes integer from pointer without a cast
togl.c:2420: warning: passing argument 5 of ‘Tk_SetGrid’ makes integer from pointer without a cast
togl.c:2422: error: dereferencing pointer to incomplete type
togl.c:2422: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2422: warning: passing argument 1 of ‘Tk_UnsetGrid’ from incompatible pointer type
togl.c: In function ‘ToglCmdDeletedProc’:
togl.c:2445: error: dereferencing pointer to incomplete type
togl.c:2445: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2484: error: dereferencing pointer to incomplete type
togl.c:2484: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:2487: error: dereferencing pointer to incomplete type
togl.c:2487: error: request for member ‘TkWin’ in something not a structure or union
togl.c: In function ‘Togl_Destroy’:
togl.c:2509: error: dereferencing pointer to incomplete type
togl.c:2509: error: request for member ‘display’ in something not a structure or union
togl.c:2509: warning: passing argument 3 of ‘Tk_FreeOptions’ from incompatible pointer type
togl.c:2512: error: dereferencing pointer to incomplete type
togl.c:2512: error: request for member ‘Cursor’ in something not a structure or union
togl.c:2513: error: dereferencing pointer to incomplete type
togl.c:2513: error: request for member ‘display’ in something not a structure or union
togl.c:2513: error: request for member ‘Cursor’ in something not a structure or union
togl.c:2513: warning: passing argument 1 of ‘Tk_FreeCursor’ from incompatible pointer type
togl.c:2513: warning: passing argument 2 of ‘Tk_FreeCursor’ from incompatible pointer type
togl.c:2516: error: dereferencing pointer to incomplete type
togl.c:2516: error: request for member ‘DestroyProc’ in something not a structure or union
togl.c:2517: error: dereferencing pointer to incomplete type
togl.c:2517: error: request for member ‘DestroyProc’ in something not a structure or union
togl.c:2517: error: called object ‘&<erroneous-expression>’ is not a function
togl.c: In function ‘Togl_EventProc’:
togl.c:2542: error: dereferencing pointer to incomplete type
togl.c:2542: error: request for member ‘UpdatePending’ in something not a structure or union
togl.c:2543: error: dereferencing pointer to incomplete type
togl.c:2543: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2543: error: ‘struct Tk_ConfigSpec’ has no member named ‘window’
togl.c:2543: warning: comparison between pointer and integer
togl.c:2556: error: dereferencing pointer to incomplete type
togl.c:2556: error: request for member ‘Width’ in something not a structure or union
togl.c:2556: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2556: error: ‘struct Tk_ConfigSpec’ has no member named ‘changes’
togl.c:2556: error: request for member ‘width’ in something not a structure or union
togl.c:2557: error: dereferencing pointer to incomplete type
togl.c:2557: error: request for member ‘Height’ in something not a structure or union
togl.c:2557: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2557: error: ‘struct Tk_ConfigSpec’ has no member named ‘changes’
togl.c:2557: error: request for member ‘height’ in something not a structure or union
togl.c:2558: error: dereferencing pointer to incomplete type
togl.c:2558: error: request for member ‘Width’ in something not a structure or union
togl.c:2558: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2558: error: ‘struct Tk_ConfigSpec’ has no member named ‘changes’
togl.c:2558: error: request for member ‘width’ in something not a structure or union
togl.c:2559: error: dereferencing pointer to incomplete type
togl.c:2559: error: request for member ‘Height’ in something not a structure or union
togl.c:2559: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2559: error: ‘struct Tk_ConfigSpec’ has no member named ‘changes’
togl.c:2559: error: request for member ‘height’ in something not a structure or union
togl.c:2560: error: dereferencing pointer to incomplete type
togl.c:2560: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2560: error: ‘struct Tk_ConfigSpec’ has no member named ‘display’
togl.c:2561: error: dereferencing pointer to incomplete type
togl.c:2561: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2561: error: ‘struct Tk_ConfigSpec’ has no member named ‘window’
togl.c:2561: error: request for member ‘Width’ in something not a structure or union
togl.c:2561: error: request for member ‘Height’ in something not a structure or union
togl.c:2561: warning: passing argument 1 of ‘XResizeWindow’ from incompatible pointer type
togl.c:2561: warning: passing argument 2 of ‘XResizeWindow’ makes integer from pointer without a cast
togl.c:2561: warning: passing argument 3 of ‘XResizeWindow’ makes integer from pointer without a cast
togl.c:2561: warning: passing argument 4 of ‘XResizeWindow’ makes integer from pointer without a cast
togl.c:2571: error: dereferencing pointer to incomplete type
togl.c:2571: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c:2572: error: dereferencing pointer to incomplete type
togl.c:2572: error: request for member ‘ReshapeProc’ in something not a structure or union
togl.c:2572: error: called object ‘&<erroneous-expression>’ is not a function
togl.c:2574: error: dereferencing pointer to incomplete type
togl.c:2574: error: request for member ‘Width’ in something not a structure or union
togl.c:2574: error: request for member ‘Height’ in something not a structure or union
togl.c:2574: warning: passing argument 3 of ‘glViewport’ makes integer from pointer without a cast
togl.c:2574: warning: passing argument 4 of ‘glViewport’ makes integer from pointer without a cast
togl.c:2594: warning: ‘AGLDrawable’ is deprecated
togl.c:2594: error: dereferencing pointer to incomplete type
togl.c:2594: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2594: error: ‘struct Tk_ConfigSpec’ has no member named ‘window’
togl.c:2594: warning: passing argument 1 of ‘TkMacOSXGetDrawablePort’ makes integer from pointer without a cast
togl.c:2596: warning: ‘aglSetDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:322)
togl.c:2596: error: dereferencing pointer to incomplete type
togl.c:2596: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2596: warning: passing argument 1 of ‘aglSetDrawable’ from incompatible pointer type
togl.c:2610: warning: ‘aglSetDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:322)
togl.c:2610: error: dereferencing pointer to incomplete type
togl.c:2610: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2610: warning: passing argument 1 of ‘aglSetDrawable’ from incompatible pointer type
togl.c:2615: error: dereferencing pointer to incomplete type
togl.c:2615: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2616: error: dereferencing pointer to incomplete type
togl.c:2616: error: request for member ‘SetGrid’ in something not a structure or union
togl.c:2617: error: dereferencing pointer to incomplete type
togl.c:2617: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2617: warning: passing argument 1 of ‘Tk_UnsetGrid’ from incompatible pointer type
togl.c:2619: error: dereferencing pointer to incomplete type
togl.c:2619: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2622: error: dereferencing pointer to incomplete type
togl.c:2622: error: request for member ‘Interp’ in something not a structure or union
togl.c:2622: error: request for member ‘widgetCmd’ in something not a structure or union
togl.c:2622: warning: passing argument 1 of ‘Tcl_DeleteCommandFromToken’ from incompatible pointer type
togl.c:2622: warning: passing argument 2 of ‘Tcl_DeleteCommandFromToken’ from incompatible pointer type
togl.c:2625: error: dereferencing pointer to incomplete type
togl.c:2625: error: request for member ‘TimerProc’ in something not a structure or union
togl.c:2627: error: dereferencing pointer to incomplete type
togl.c:2627: error: request for member ‘timerHandler’ in something not a structure or union
togl.c:2627: warning: passing argument 1 of ‘Tcl_DeleteTimerHandler’ from incompatible pointer type
togl.c:2633: error: dereferencing pointer to incomplete type
togl.c:2633: error: request for member ‘UpdatePending’ in something not a structure or union
togl.c: In function ‘Togl_PostRedisplay’:
togl.c:2658: error: dereferencing pointer to incomplete type
togl.c:2658: error: request for member ‘UpdatePending’ in something not a structure or union
togl.c:2659: error: dereferencing pointer to incomplete type
togl.c:2659: error: request for member ‘UpdatePending’ in something not a structure or union
togl.c: In function ‘Togl_SwapBuffers’:
togl.c:2669: error: dereferencing pointer to incomplete type
togl.c:2669: error: request for member ‘DoubleFlag’ in something not a structure or union
togl.c:2677: error: dereferencing pointer to incomplete type
togl.c:2677: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:2677: warning: passing argument 1 of ‘aglSwapBuffers’ from incompatible pointer type
togl.c: In function ‘Togl_Ident’:
togl.c:2689: error: dereferencing pointer to incomplete type
togl.c:2689: error: request for member ‘Ident’ in something not a structure or union
togl.c:2689: warning: return from incompatible pointer type
togl.c: In function ‘Togl_Width’:
togl.c:2696: error: dereferencing pointer to incomplete type
togl.c:2696: error: request for member ‘Width’ in something not a structure or union
togl.c:2696: warning: return makes integer from pointer without a cast
togl.c: In function ‘Togl_Height’:
togl.c:2703: error: dereferencing pointer to incomplete type
togl.c:2703: error: request for member ‘Height’ in something not a structure or union
togl.c:2703: warning: return makes integer from pointer without a cast
togl.c: In function ‘Togl_Interp’:
togl.c:2710: error: dereferencing pointer to incomplete type
togl.c:2710: error: request for member ‘Interp’ in something not a structure or union
togl.c:2710: warning: return from incompatible pointer type
togl.c: In function ‘Togl_TkWin’:
togl.c:2717: error: dereferencing pointer to incomplete type
togl.c:2717: error: request for member ‘TkWin’ in something not a structure or union
togl.c:2717: warning: return from incompatible pointer type
togl.c: In function ‘Togl_AllocColor’:
togl.c:2913: error: dereferencing pointer to incomplete type
togl.c:2913: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:2919: error: dereferencing pointer to incomplete type
togl.c:2919: error: request for member ‘PrivateCmapFlag’ in something not a structure or union
togl.c: In function ‘Togl_FreeColor’:
togl.c:2958: error: dereferencing pointer to incomplete type
togl.c:2958: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:2964: error: dereferencing pointer to incomplete type
togl.c:2964: error: request for member ‘PrivateCmapFlag’ in something not a structure or union
togl.c: In function ‘Togl_SetColor’:
togl.c:2984: error: dereferencing pointer to incomplete type
togl.c:2984: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:2989: error: dereferencing pointer to incomplete type
togl.c:2989: error: request for member ‘PrivateCmapFlag’ in something not a structure or union
togl.c: In function ‘Togl_LoadBitmapFont’:
togl.c:3143: warning: ‘aglUseFont’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:383)
togl.c:3143: error: dereferencing pointer to incomplete type
togl.c:3143: error: request for member ‘aglCtx’ in something not a structure or union
togl.c:3145: warning: passing argument 1 of ‘aglUseFont’ from incompatible pointer type
togl.c: In function ‘Togl_UseLayer’:
togl.c:3196: error: dereferencing pointer to incomplete type
togl.c:3196: error: request for member ‘OverlayWindow’ in something not a structure or union
togl.c: In function ‘Togl_HideOverlay’:
togl.c:3250: error: dereferencing pointer to incomplete type
togl.c:3250: error: request for member ‘OverlayWindow’ in something not a structure or union
togl.c:3250: error: request for member ‘OverlayIsMapped’ in something not a structure or union
togl.c:3251: error: dereferencing pointer to incomplete type
togl.c:3251: error: request for member ‘TkWin’ in something not a structure or union
togl.c:3251: error: ‘struct Tk_ConfigSpec’ has no member named ‘display’
togl.c:3251: error: request for member ‘OverlayWindow’ in something not a structure or union
togl.c:3251: warning: passing argument 1 of ‘XUnmapWindow’ from incompatible pointer type
togl.c:3251: warning: passing argument 2 of ‘XUnmapWindow’ makes integer from pointer without a cast
togl.c:3252: error: dereferencing pointer to incomplete type
togl.c:3252: error: request for member ‘OverlayIsMapped’ in something not a structure or union
togl.c: In function ‘Togl_PostOverlayRedisplay’:
togl.c:3260: error: dereferencing pointer to incomplete type
togl.c:3260: error: request for member ‘OverlayUpdatePending’ in something not a structure or union
togl.c:3261: error: dereferencing pointer to incomplete type
togl.c:3261: error: request for member ‘OverlayWindow’ in something not a structure or union
togl.c:3261: error: request for member ‘OverlayDisplayProc’ in something not a structure or union
togl.c:3263: error: dereferencing pointer to incomplete type
togl.c:3263: error: request for member ‘OverlayUpdatePending’ in something not a structure or union
togl.c: In function ‘Togl_ExistsOverlay’:
togl.c:3278: error: dereferencing pointer to incomplete type
togl.c:3278: error: request for member ‘OverlayFlag’ in something not a structure or union
togl.c:3278: warning: return makes integer from pointer without a cast
togl.c: In function ‘Togl_GetOverlayTransparentValue’:
togl.c:3285: error: dereferencing pointer to incomplete type
togl.c:3285: error: request for member ‘OverlayTransparentPixel’ in something not a structure or union
togl.c:3285: warning: return makes integer from pointer without a cast
togl.c: In function ‘Togl_IsMappedOverlay’:
togl.c:3292: error: dereferencing pointer to incomplete type
togl.c:3292: error: request for member ‘OverlayFlag’ in something not a structure or union
togl.c:3292: error: request for member ‘OverlayIsMapped’ in something not a structure or union
togl.c: In function ‘Togl_GetClientData’:
togl.c:3341: error: dereferencing pointer to incomplete type
togl.c:3341: error: request for member ‘Client_Data’ in something not a structure or union
togl.c: In function ‘Togl_SetClientData’:
togl.c:3348: error: dereferencing pointer to incomplete type
togl.c:3348: error: request for member ‘Client_Data’ in something not a structure or union
togl.c: In function ‘Togl_Display’:
togl.c:3360: error: dereferencing pointer to incomplete type
togl.c:3360: error: request for member ‘TkWin’ in something not a structure or union
togl.c:3360: error: ‘struct Tk_ConfigSpec’ has no member named ‘display’
togl.c:3360: warning: return from incompatible pointer type
togl.c: In function ‘Togl_Screen’:
togl.c:3366: error: dereferencing pointer to incomplete type
togl.c:3366: error: request for member ‘TkWin’ in something not a structure or union
togl.c:3366: error: ‘struct Tk_ConfigSpec’ has no member named ‘display’
togl.c:3366: error: ‘struct Tk_ConfigSpec’ has no member named ‘screens’
togl.c:3366: error: ‘struct Tk_ConfigSpec’ has no member named ‘screenNum’
togl.c:3366: error: array subscript is not an integer
togl.c:3366: warning: return from incompatible pointer type
togl.c: In function ‘Togl_ScreenNumber’:
togl.c:3372: error: dereferencing pointer to incomplete type
togl.c:3372: error: request for member ‘TkWin’ in something not a structure or union
togl.c:3372: error: ‘struct Tk_ConfigSpec’ has no member named ‘screenNum’
togl.c:3372: warning: return makes integer from pointer without a cast
togl.c: In function ‘Togl_Colormap’:
togl.c:3378: error: dereferencing pointer to incomplete type
togl.c:3378: error: request for member ‘TkWin’ in something not a structure or union
togl.c:3378: error: ‘struct Tk_ConfigSpec’ has no member named ‘atts’
togl.c:3378: error: request for member ‘colormap’ in something not a structure or union
togl.c:3378: warning: return makes integer from pointer without a cast
togl.c: In function ‘Togl_DumpToEpsFile’:
togl.c:3699: error: dereferencing pointer to incomplete type
togl.c:3699: error: request for member ‘Width’ in something not a structure or union
togl.c:3699: error: request for member ‘Height’ in something not a structure or union
togl.c:3729: error: dereferencing pointer to incomplete type
togl.c:3729: error: request for member ‘RgbaFlag’ in something not a structure or union
togl.c:3750: error: dereferencing pointer to incomplete type
togl.c:3750: error: request for member ‘EpsMapSize’ in something not a structure or union
togl.c:3750: error: request for member ‘EpsRedMap’ in something not a structure or union
togl.c:3750: warning: passing argument 2 of ‘glPixelMapfv’ makes integer from pointer without a cast
togl.c:3750: warning: passing argument 3 of ‘glPixelMapfv’ from incompatible pointer type
togl.c:3751: error: dereferencing pointer to incomplete type
togl.c:3751: error: request for member ‘EpsMapSize’ in something not a structure or union
togl.c:3751: error: request for member ‘EpsGreenMap’ in something not a structure or union
togl.c:3751: warning: passing argument 2 of ‘glPixelMapfv’ makes integer from pointer without a cast
togl.c:3751: warning: passing argument 3 of ‘glPixelMapfv’ from incompatible pointer type
togl.c:3752: error: dereferencing pointer to incomplete type
togl.c:3752: error: request for member ‘EpsMapSize’ in something not a structure or union
togl.c:3752: error: request for member ‘EpsBlueMap’ in something not a structure or union
togl.c:3752: warning: passing argument 2 of ‘glPixelMapfv’ makes integer from pointer without a cast
togl.c:3752: warning: passing argument 3 of ‘glPixelMapfv’ from incompatible pointer type
make[1]: *** [OBJ.i386-apple-darwin9.6.0/togl.o] Error 1
make: *** [default] Error 2
