[GRASS-dev] GRASS 7 nviz (tcltk) no longer compiles on Mac
Michael Barton
michael.barton at asu.edu
Sun Feb 1 13:07:35 EST 2009
On Feb 1, 2009, at 9:37 AM, William Kyngesburye wrote:
> On Feb 1, 2009, at 9:50 AM, Michael Barton wrote:
>>>> Just did an update and compile from the SVN. The original TclTk
>>>> version of nviz will no longer compile on the Mac. I wonder if
>>>> this is
>>>> related to the change to make it TclTk 8.6 compatible?
>>>> Anyway, I put the lengthy error into a text file and am attaching
>>>> it.
>>>> In file included from togl.c:53:
>>>> /usr/include/tkMacOSX.h:19:19: error: tkInt.h: No such file or
>>>> directory
>>> It looks like the headers from the system Tk package are broken.
> But it shouldn't be trying to use the system tcltk in the first
> place. So the tests in configure probably failed to find your tcltk
> 8.5.
>> I compiled 6.5 a few minutes earlier and had no problem with TclTk.
>> One thing I noticed. In platform make, I normally have to edit the
>> TCLTKLIBS line from
>> TCLTKLIBS = -ltk -ltcl
>> to
>> TCLTKLIBS = -framework Tcl -framework Tk
> I haven't had to do that in a while. I added symlinks to /usr/local/
> lib (I think we discussed this a while back).
For a variety of reasons--including needing the x11 version of TclTk
8.5 for some other things--I had to get rid of the symlinks. This
means I'm back to modifying platform.make
This works fine for GRASS 6.5. So what has changed for 7 in this
regard? I guess I can explicitly set the path to the frameworks in the
configure line and see what happens.
Michael
