[GRASS-dev] Re: [GRASS GIS] #426: v.in.ogr: split long boundaries
trac at osgeo.org
Wed Feb 4 11:52:10 EST 2009
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.5.0
Component: Vector | Version: unspecified
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by mmetz):
The attached patch is against devbr_6 r35761 and would give a bit of a
speed up and adds safety checks.
I added boundary splitting activated with a new -s flag, the speed
increase is zero to 6x, depending on the import vector.
The patch uses a temporary vector, this can reduce final coor file size by
a factor of 2 to 5 if a shapefile with polygons is imported.
Vector libraries do not support large files > 2GB, therefore my complaint
no 2) above is not valid and the error message is valid.
Closing a vector and opening again works like a file size limit check. The
patch does that not only before cleaning polygons as in the current
v.in.ogr (this is a very nice idea, it would be annoying to get a vector
cleaned for hours that was corrupt anyway...), it also checks file size
limits just before copying the temporary vector to the final output
vector. If that check is passed, only alive features of the temporary
vector are copied to the output vector, giving the file size reduction in
case polygons were cleaned. New warning messages appear when checking file
size limits (checking file size limits is done by the vector library when
opening a vector, I didn't come up with a weird new solution:-)).
Please test!
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/426#comment:5>
