[GRASS-dev] Re: [GRASS GIS] #469: raster data needs binary mode on
windows
trac at osgeo.org
Wed Feb 4 19:48:32 EST 2009
#469: raster data needs binary mode on windows
Reporter: jef | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:13 glynn]:
> I think that you need to modify ARCH_LIB_OBJS (which has the $(OBJDIR)/
prefix added) on 6.x. That uses eager assignment (:=), so its value is set
based upon the value of $(LIB_OBJS) at the point that Lib.make is
included; subsequent changes to LIB_OBJS won't have any effect.
Scratch that; it won't work in 6.x. The only way to override the list of
object files is to fully define LIB_OBJS '''before''' Lib.make is
included, e.g.:
LIB_OBJS := $(subst .c,.o,$(wildcard *.c))
LIB_OBJS := $(filter-out fmode.o dllmain.o,$(LIB_OBJS))
> 7.0 added an extra lazy assignment step to make it easier to override
the list of object files.
It also separated out the variable definitions from the rules, so that you
can override variables after including Vars.make but before including e.g.
Lib.make.
6.x doesn't have this; you can't get at the variables before the rules
which use them are defined. So, you can't modify any variables which are
used in dependency lines, as those are expanded as they are read. You can
override variables which are used in commands, as those aren't expanded
until the commands are executed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/469#comment:14>
