[GRASS-dev] anyone working with ps.map?
Hamish
hamish_b at yahoo.com
Wed Feb 4 22:27:43 EST 2009
Jorge Tizado wrote:
> I am modified some files of ps.map to improve vlegend.
> Anyone worling in the same direction?
yes,
which version of the source code are you working against?
ps.map's vlegend placement was improved/fixed a couple of months ago in
SVN. you should now be able to place the legend wherever you like it
and set custom column width. see http://trac.osgeo.org/grass/ticket/355
This is in SVN now and will be in the 6.4 and grass7 releases.
Hamish
ps- C++ style //coments are not encouraged. see SUBMITTING.
pps- please submit significant patches to the trac system, as they easily
get lost in the noise if posted to the mailing lists.
