[GRASS-dev] r.surf.contour inefficiency?
Glynn Clements
glynn at gclements.plus.com
Sun Feb 8 02:26:54 EST 2009
Hamish wrote:
> > I presume that it's the use of the segment library causing a lot of I/O.
> > Can r.surf.contour reasonably be used on gigabyte-sized maps?
> currently it is so slow to run that working with such a big map would
> not complete in a reasonable time.
I'll remove the segmentation code in 7.0.
