[GRASS-dev] Re: [GRASS GIS] #398: r.watershed with MFD
trac at osgeo.org
Mon Feb 9 04:14:23 EST 2009
Reporter: mmetz | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: reopened
Priority: minor | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by mmetz):
Helena Mitasova and Michael Barton asked previously about backporting
r.watershed with MFD to grass6. Now that develbranch_6 stays as version
6.5.svn, does someone have objections against backporting r.watershed from
trunk to develbranch_6?
It would be backported with the following modifications for backwards
compatibility:
disable MFD by default, it will be enabled with a new -f flag. I don't
want to (ab)use the -s flag of trunk because it has the opposite meaning.
The -s flag will be removed.
RUSLE LS and S factors will again be multiplied by 100, as before. The
output raster type of the LS and S factors has to be changed to DCELL
though, otherwise MFD won't work, because flow accumulation needs to be of
type DCELL for MFD, i.e. always, and the segmented mode uses the same
function for writing out any variable of type DCELL. Previously, LS and S
factor were stored as type DCELL, but both in segmented mode and in ram
mode written out as type (CELL) (factor * 100). This change from CELL to
DCELL can not be reverted, at the same time supporting flow accumulation
output as type DCELL, without a lot of rewriting, actually more rewriting
than was necessary to implement MFD support. The change from CELL to DCELL
for flow accumulation and the RUSLE factors will hopefully not break
scripts.
I would need some help on how to properly backport the various changes
from trunk to devbr6. According to the svn howto, svn merge backports one
particular change if I got that right.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/398#comment:8>
