[GRASS-dev] [GRASS GIS] #488: v.db.addcol/v.rast.stats not working
trac at osgeo.org
Mon Feb 9 13:44:47 EST 2009
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.db.addcol v.rast.stats | Platform: MSWindows Vista
Cpu: Unspecified |
osgeo4w (2008/02/08):
grass64rc3-2
GDAL 1.5.4, released 2009/01/07
data:
gisdemo_ncspm
g.gisenv --v
GISDBASE='C:\gisdata\grassdata';
LOCATION_NAME='gisdemo_ncspm';
MAPSET='user1';
GRASS_GUI='wxpython';
"DEBUG='3"';
r.random -d input=elevation at PERMANENT n=100 vector_output=vrand
v.buffer --verbose input=vrand at user1 output=vrandb distance=10
minordistance=10
v.category input=vrandb at user1 output=vrandb2 at user1
db.tables -p
streetstest
vrand
=> no table for vector vrandb2
=> create table for vector via "Attribute table manager-Manage Layer -
Create table":
Table Description: Table name => vrandb, Key colomn => cat
db.tables -p
streetstest
vrand
vrandb2
=> add layer and set to default via "Attribute table manager-Manage Layer
- Add layer"
v.info map=vrandb2 at user1
| Layer: vrandb2 at user1
| Mapset: user1
| Database: C:\gisdata\grassdata
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: syringia
| Organization:
| Source date: Mon Feb 09 18:08:02 2009
| Type of Map: vector (level: 2)
| Number of points: 0 Number of areas: 100
| Number of lines: 0 Number of islands: 100
| Number of boundaries: 100 Number of faces: 0
| Number of centroids: 100 Number of kernels: 0
| Map is 3D: No
| Number of dblinks: 1
| Projection: Lambert Conformal Conic
| N: 228129.97668769 S: 215100.02331231
| E: 644720 W: 630530.09314054
| Digitization threshold: 0
| Comments:
=> table/layer linked
=> check table/coloumns in vrandb2-table
db.columns table=vrandb2
cat
db.describe -c table=vrandb2
ncols: 1
nrows: 100
Column 1: cat:INTEGER:11
v.info -c map=vrandb2 at user1
Displaying column types/names for database connection of
layer 1:
INTEGER|cat
=> example from the manual: v.db.addcol sentiero_brenta_points
columns="slope double precision"
=> add new coloumn in vrandb2-table:
v.db.addcol map=vrandb2 at user1 columns="barea double precision"
C:/OSGeo4W/apps/grass/grass-6.4.0RC3/scripts/v.db.addcol:
eval: line 1: unexpected EOF while looking for matching
eval: line 2: syntax error: unexpected end of file
GISDBASE: parameter null or not set
=> no column added
layer 1:
INTEGER|cat
=> similar error messages for v.rast.stat
g.region -p rast=elevation at PERMANENT
v.rast.stats -e --verbose vector=vrandb2 at user1
raster=elevation at PERMANENT colprefix=els
C:/OSGeo4W/apps/grass/grass-6.4.0RC3/scripts/v.rast.stats:
Ticket URL: <http://trac.osgeo.org/grass/ticket/488>
