[GRASS-dev] vector large file support
Tue Feb 10 05:15:19 EST 2009
Markus Metz wrote:
> >> I got confused by this endian-ness and confused low/high word with
> >> first/second word. With the current code, the low word would be the
> >> second word when doing 2 32bit reads on a 64bit sized buffer,
> >> independent on a endian-ness mismatch. In this case, the libs would have
> >> to check if the high word is != 0 and then exit with an ERROR message,
> >> right?
> > Right. The files are always written big-endian, so the high word will
> > always be first in the file.
> I'm not so sure about that, why is byte order stored in the topo header?
> Byte order for writing out is determined just before writing topo/cidx.
Okay; maybe that's just the internal default. I'm looking at
dig_init_portable(), which copies the *_cnvrt arrays for big-endian
and reverses them for little-endian.
I don't know why that code needs to be so obtuse.
> > As well as checking that the high word is zero, you also need to check
> > that the low word is <= 0x7fffffff (off_t is signed, hence the limit
> > being 2GiB not 4GiB).
> OK. Additionally the whole thing should not be negative, that would be
> an invalid offset.
I'm assuming that the individual words are treated as unsigned.
