[GRASS-dev] Re: [GRASS GIS] #474: r.quantile: segfaults with percentile=100
GRASS GIS trac at osgeo.org
Wed Feb 11 05:21:46 EST 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  closed
  Priority:  major   |   Milestone:  6.4.0
 Component:  Raster  |     Version:  svn-develbranch6
Resolution:  fixed   |    Keywords:  r.quantile
  Platform:  Linux   |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:4 hamish]:
 > I notice that if you do 'quant=3' you only get 2 results, and 'quant=1'
 gives no output. (all others do the same, report n-1)
 > Is this intended because 3 bins will have two separators (at 33% and
 66%), or is it a bug?
 It's intended so that quant=N gives "N-tiles", e.g. quant=4 gives
 quartiles, quant=10 gives deciles, etc. AIUI, the convention is not to
 include the endpoints, e.g. "quartiles" are given as 25%, 50%, and 75%.
Ticket URL: <https://trac.osgeo.org/grass/ticket/474#comment:5>
