[GRASS-dev] [GRASS GIS] #492: grass7: XY-location makes g.region segfault
GRASS GIS trac at osgeo.org
Wed Feb 11 10:51:31 EST 2009
 Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  default      |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 1) create location through wxgui wizard, option "Use arbitrary non-earth
 coordinate system (XY)" or option "Use coordinate system of selected
 georeferenced file" pointing at a non-georeferenced file.
 2) g.region -p gives:
 GRASS 7.0.svn (XY):~ > g.region -p
 WARNING: <PROJ_INFO> file not found for location <XY>
 WARNING: <PROJ_UNITS> file not found for location <XY>
 Segmentation fault
 This also leads to a crash of the GUI. I'll report this as a separate bug.
 devel6-tree does not show this problem.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/492>
