[GRASS-dev] Re: [osgeo4w] #37: grass: wxpython gui issues
OSGeo4W trac_osgeo4w at osgeo.org
Fri Feb 13 12:05:49 EST 2009
  Reporter:  jachym   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:
 Component:  Package  |     Version:
Resolution:           |    Keywords:  GRASS
Comment (by jef):
 Replying to [comment:17 martinl]:
 > to be more clear I meant to obtain a receipt to compile wxvdigit
 extension for grass package.
 I initially compiled with Visual C++ 2008 Express Edition, which led to
 similar results.  Suspecting subtle compiler incompabilities I switched to
 Visual C++ 7.1, which is what OSGeo4W's python is compiled with and the
 default for distutils. Obviously that didn't help either.
 I have attached what I use to build the extensions from the command prompt
 started with {{{OSGeo4W-vc7.bat}}}. But I'm not sure if it's complete.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/37#comment:18>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
