[GRASS-dev] vector large file support
Glynn Clements
glynn at gclements.plus.com
Mon Feb 16 11:00:07 EST 2009
Markus Metz wrote:
> I suspect the bugs in rtree to be in index.c at line 119
> b.child = (struct Node *)tid;
> b.child is a pointer to the next node in the RTree. tid is the line
> number for which a new bounding box will be inserted in the RTree. This
> is a cast from integer to pointer, giving a compile time warning.
> and at lines 284 - 286
> RTreeInsertRect(&(tmp_nptr->branch[i].rect),
> (int)tmp_nptr->branch[i].child, <-- cast from pointer to integer of different size
> nn, tmp_nptr->level);
> I understand the concept of RTrees better than this code, but I suspect
> that at line 119, line number is used as memory address for a pointer
> and at line 285, the memory address of a pointer is used as line number.
> Can you developer cracks confirm that?
ISTR something like that. This isn't necessarily a problem, so long
as:
1. The field is wide enough to hold both types.
2. The code doesn't attempt to read an integer when a pointer was
stored, and vice versa.
Having said that, using a union would be preferable. Using distinct
fields would be more robust (although use slightly more memory), as
that would enable point #2 above to be verified at run-time.
> line 285 was the bug causing the segfault when cleaning large vectors. I
> gave the RTree Branch structure a new variable, its id, and used the id
> where appropriate and pointer where appropriate, and got the above
> described results (also no more compile warnings).
> IMHO stuff like this needs to be sorted out before the vector libs get LFS.
> What should I do now? Submit a patch to trac or commit to trunk or leave
> it open for discussion?
I suggest committing it. AFAIK, no-one really understands the rtree
code, so I doubt that you'll get much feedback from a patch.
