[GRASS-dev] [GRASS GIS] #496: g.rename vect=Map1,map1 doesn't work
GRASS GIS trac at osgeo.org
Tue Feb 17 00:49:10 EST 2009
 Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.0
Component:  Vector    |     Version:  6.4.0 RCs
 Keywords:  g.rename  |    Platform:  Linux
      Cpu:  x86-32    |
 is a no-op. The map is not renamed. :(
 in the above example there was no attached DB. not sure what happens if
 there is (ie partial rename->breakage?).
 perhaps due to some MS-Windows accommodation which has gone too far?
 I've been using case sensitive names for years to indicate type of map /
 protection from typos. Losing the ability to manage them properly or
 having all treated as lowercase() would stink.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/496>
