[GRASS-dev] ps3.map: join two rasters
Hamish
hamish_b at yahoo.com
Wed Feb 18 02:35:30 EST 2009
Benjamin:
> would you be willing to put some tutorial on the GRASS Wiki to show
> users how to generate such maps with ps3.map?
-> http://grass.osgeo.org/wiki/Ps.map_scripts#Script_examples
Jorge:
> > It is interesting the posibility of gradient legend in
> > CELL map;
my crappy work around for that was to run
r.mapcalc "float_map = float(cell_map)"
r.colors float_map rast=cell_map
and then use the float_map with ps.map.
> > But the better improve (just run without problems) is
> > merge two raster maps
and the previous crappy work around here was to use r.mapcalc's r#map,
g#map, b#map operators and patch the two maps for each band.
Also 'd.rast -o'; set GRASS_WIDTH,GRASS_HEIGHT to region size, then
run 'd.out.file format=geotiff' + r.in.gdal is another way.
Hamish
