[GRASS-dev] [GRASS GIS] #500: GUI menu item to swtich GUIs
GRASS GIS trac at osgeo.org
Fri Feb 20 02:53:54 EST 2009
 Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  6.4.0
Component:  default      |     Version:  6.4.0 RCs
 Keywords:  gui          |    Platform:  All
      Cpu:  All          |
 currently there is no easy way to switch the default GUI from a GUI.
 e.g. from the native windows build you typically don't start from a
 command prompt so `grass64 -wxpython` isn't an easy option. If you know
 how you can do Config -> Settings -> GRASS working environment -> Change
 settings -> GRASS variable to set -> "GRASS_GUI=wxpython"
 in the GUI, but that's hardly something that someone could figure out on
 their own.
 To make this easier, I've added a new flag to g.gui to update default GUI
 but do not launch it. (done in r35972, r35973)
 The GUI menus would need to launch "g.gui -n --ui", or a wrapper fn for
 g.gui (bash/python template: 'g.gui --script') with the -nu flags
 hardcoded and only the type pulldown menu available. Then exit with a "you
 need to restart grass to see the effect" message.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/500>
