[GRASS-dev] Re: [GRASS GIS] #499: fresh windows startup not very friendly
GRASS GIS trac at osgeo.org
Sat Feb 21 15:51:06 EST 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement   |      Status:  new
  Priority:  minor         |   Milestone:  6.4.0
 Component:  default       |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass startup
  Platform:  MSWindows XP  |         Cpu:  x86-32
Changes (by marisn):
  * priority:  major => minor
Comment:
 Replying to [comment:2 hamish]:
 > > Tcl/Tk GUI doesn't check presence of .grassrc6 or any other file.
 > my wish is that it should check for that, and if it isn't found it
 should pop up a file system browse window to help you choose/create the
 $GISDBASE dir.
 Sorry, I was wrong. Actual startup goes like this:
  * init.sh checks presence of .grassrc6 or whatever it's called for
 current version
  * if there is no one, it creates one with GISDBASE=pwd, '<UNKNOWN>'
 location etc.
  * gis_set.tcl searches for .grassrc6 file and parses it
  * after parsing rc file, it validates GISDBASE, location and mapset. As
 '<UNKNOWN>' most likely will not be valid location in current directory,
 validation procedure displays a warning.
 > > Probably it would be better to remove completely presetting
 > > location etc. in init scripts
 > no way, that's super useful. just deal with the lack of .grassrc6
 gracefully, that's all.
 Can You, please, explain usefullines of .grassrc6 file with location
 <UNKNOWN> and mapset <UNKNOWN>?
 > > As goes for GISDBASE creation, I will take a look into this
 > > problem later this weekend.
 > thanks.
 Would r35911 make things better? svn up Your develbranch, rm .grassrc6 and
 start GRASS. If it's OK, merge to release branch.
 Still it may be a good idea to set GISDBASE for first run to user home dir
 on windows. Still I have no idea how to do that. And will it work safe
 with spaces in path? Do we have windows gurus here? Hamish? Patches
 welcome :)
 Not RTFMing is not a major GRASS issue. It's PEBKAC. And if windows
 doesn't provide multitasking feature (ability to switch to other
 application to create simple folder) then is it worth to run GRASS there?
Ticket URL: <https://trac.osgeo.org/grass/ticket/499#comment:3>
