[GRASS-dev] Re: [GRASS GIS] #499: fresh windows startup not very friendly
GRASS GIS trac at osgeo.org
Sun Feb 22 01:54:30 EST 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement   |      Status:  new
  Priority:  minor         |   Milestone:  6.4.0
 Component:  default       |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass startup
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 Maris:
 > > > Probably it would be better to remove completely presetting
 > > > location etc. in init scripts
 Hamish:
 > > no way, that's super useful. just deal with the lack of
 > > .grassrc6 gracefully, that's all.
 Maris:
 > Can You, please, explain usefullines of .grassrc6 file with
 > location <UNKNOWN> and mapset <UNKNOWN>?
 I thought you meant to remove saving the last mapset etc in .grassrcX.
 nevermind. None the less, having <UNKNOWN> is a clear indicator of what is
 missing. More so than just a missing entry; it helps with debugging.
 > Would r35991 make things better?
 yes, it is nice, thank you.
 > Still it may be a good idea to set GISDBASE for first run to
 > user home dir on windows. Still I have no idea how to do that.
 me neither but a web search suggests that putting %HOMEPATH% into init.bat
 instead of %CD% might be the way. If doing that, probably sync init.sh to
 use $HOME instead of $PWD.
 > And will it work safe with spaces in path?
 no idea.
 > Do we have windows gurus here? Hamish?
 not me.
 > Not RTFMing is not a major GRASS issue.
 ... grass has 500+ FMs to read, and for many users they are in a foreign
 language. Launching the program should not require hours of study. A smart
 user should be able to figure out how to render a map  in <10 minutes. If
 they can't see that tangible feedback many will just give up and walk
 away.
 > It's PEBKAC.
 what I am saying is that unintuitive behaviour is a mistake by the
 developers, not the users.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/499#comment:5>
