[GRASS-dev] Re: [GRASS GIS] #503: wx-GUI: html-manual
GRASS GIS trac at osgeo.org
Sun Feb 22 21:41:53 EST 2009
  Reporter:  hellik       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  reopened
  Priority:  minor        |   Milestone:  6.4.0
 Component:  Docs         |     Version:  6.4.0 RCs
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by hamish):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 reopening ticket, as the problem still happens and the fix actually does
 nothing.
 'make distclean' does not remove gui/wxpython/docs/*.tmp.html. i.e. it's
 not about  $(GISBASE)/docs/html/$$file.html, it's about the .tmp.html file
 in the source dir.
 run "make" in gui/wxpython/docs/ a few times and watch them grow.
 Two problems to fix as I see it:
   - 'make clean' does not clean up the .tmp.html files in docs/
 and
   - 'make htmldir' is appending to instead of replacing the .tmp.html
 file.
 not really sure about how to fix Makefile stuff,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/503#comment:4>
