[GRASS-dev] Re: [GRASS GIS] #494: break in importing and cleaning very large vector datasets
GRASS GIS trac at osgeo.org
Mon Feb 23 03:05:35 EST 2009
  Reporter:  gisboa  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Vector  |     Version:  6.4.0 RCs
Resolution:          |    Keywords:  vector import clean build
  Platform:  All     |         Cpu:  All
Comment (by mmetz):
 Replying to [ticket:494 gisboa]:
 > I try to use Grass with large vector files, with sizes up to 0,5GB, this
 usually results in errors during import, or if not during import, then at
 least while cleaning them.
 > Tool: Break polygons
 > ERROR: G_realloc: unable to allocate 34400040 bytes at
 break_polygons.c:188
 Cleaning vector files of this size (about 0.5GB) in v.in.ogr or v.clean
 can require a lot of memory, up to 8GB. Is it possible that you ran out of
 memory? Physical memory plus swap space smaller than 8GB? If yes, increase
 physical memory and/or swap space, and try develbranch_6 instead of
 6.4.0RC3.
Ticket URL: <http://trac.osgeo.org/grass/ticket/494#comment:2>
