[GRASS-dev] Re: [GRASS GIS] #175: v.to.rast labelcol= SegFaults and
ignored
trac at osgeo.org
Mon Feb 23 03:57:40 EST 2009
#175: v.to.rast labelcol= SegFaults and ignored
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords: v.to.rast
Platform: Unspecified | Cpu: Unspecified
Comment (by mmetz):
Replying to [ticket:175 hamish]:
> Hi,
> v.to.rast segfaults with the labelcolumn= option:
#spearfish
G64> g.region -d
G64> v.to.rast in=fields out=fields.v2r labelcol=label col=cat
WARNING: Area without centroid (may be OK for island)
Converted areas: 65 of 65
Converted points/lines: 0 of 0
Segmentation fault
I get the segfault too with the above command, but not with
v.to.rast in=fields out=fields.v2r labelcol=label use=cat
The labels of fields.v2r are wrong, they read like
1:Category 1
Category 0 is now skipped ???
Altogether strange behaviour of v.to.rast...
I used devbr6
Ticket URL: <http://trac.osgeo.org/grass/ticket/175#comment:6>
