[GRASS-dev] [GRASS GIS] #506: v.out.ascii segfault when exporting columns from the attribute table
GRASS GIS trac at osgeo.org
Tue Feb 24 16:44:02 EST 2009
 Reporter:  dylan        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.5.0
Component:  default      |     Version:  svn-develbranch6
 Keywords:  v.out.ascii  |    Platform:  Unspecified
      Cpu:  Unspecified  |
 v.out.ascii is giving a segfault when a column is supplied to the
 'columns' argument. Example with the spearfish database:
 v.out.ascii in=bugsites format=point columns=str1
 D4/5: eval_node node_type = 2
 D4/5:     right = 2
 D4/5:     right_dval = 1.000000
 D4/5:     operator = 11
 D4/5: condition = 0
 D2/5: load_table_head(): tab = 2,
 /home/dylan/grass/spearfish60/PERMANENT/dbf//bugsites.dbf
 Segmentation fault
 I have tried this with several vector files using the DBF backend, all
 with the same result. Using the MySQL backend v.out.ascii appears to work
 fine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/506>
