[GRASS-dev] Re: [GRASS GIS] #500: GUI menu item to swtich GUIs
GRASS GIS trac at osgeo.org
Wed Feb 25 20:56:34 EST 2009
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  gui
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 I tried the following patch, it seemed to work from the commandline with
 --ui, but still not from d.m.
 Index: gui/scripts/g.change.gui.sh
 --- gui/scripts/g.change.gui.sh (revision 36060)
 +++ gui/scripts/g.change.gui.sh (working copy)
 @@ -41,6 +41,11 @@
      exit 1
  fi
 +if [ ! -x "`which $(basename "$0")`" ] ; then
 +    PATH="$PATH:$GISBASE/etc/gui/scripts"
 +    export PATH
 +fi
  if [ "$1" != "@ARGS_PARSED@" ] ; then
      exec g.parser "$0" "$@"
  fi
 Running it from the wxPython GUI still needs to be tested by someone
 please.  Config -> Working enviro -> Change default GUI
 Also, I was thinking it could be useful to add an entry after 'Help->About
 system' like 'Help->Show system environment' which would run "set" and
 dump the results to the Output window. It would help in debugging.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/500#comment:6>
