[GRASS-dev] [GRASS GIS] #510: bad display in the Output window for
r.report and r.stats with aspect maps.
trac at osgeo.org
Thu Feb 26 09:30:03 EST 2009
#510: bad display in the Output window for r.report and r.stats with aspect maps.
Reporter: clerici | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: | Platform: Linux
Cpu: Unspecified |
r.report and r.stats for aspect maps produce ordered tables if saved in a
file but randomly disordered if displayed in the Output window.[[BR]]
In detail:[[BR]]
1) r.report for aspect map in Spearfish gives always bad (and different)
results as reported in the attachment N.1[[BR]]
2) r.stats has a random behaviour as usually displays correct results, but
sometimes the table is incorrect as in the example of the attachment N.2
No problem with GRASS6.3.
Greetings
Aldo Clerici
Ticket URL: <http://trac.osgeo.org/grass/ticket/510>
