[GRASS-dev] large vector and indices, speed up db
Vincent Bain
bain at toraval.fr
Fri Feb 27 03:27:04 EST 2009
Thank you Moritz and Wouter,
personnaly used to operating directly on tables through a psql terminal,
I am not aware of the actual performances of db.* modules.
In the present case, programming special interfaces for end-users who
massively implement vector attributes, maybe it would be a good idea to
use native dbms modules instead of db.*, e.g. if I program in perl, act
on my data through DBI DBD::pg module.
Vincent
Le jeudi 26 février 2009 à 18:37 +0100, Wouter Boasson a écrit :
> In response to:
> >Hello,
> >reading this thread, and being sometimes concerned with large vector
> >files (associated with big related tables), I wonder if it's worth
> >manually creating indexes (on cat field) : can it be a effective way to
> >speed up queries, or is the kink elsewhere, at the geometric level (data
> >handled by grass, not the linked DBMS) ?
> >Thank you,
> >Vincent
> The problems with querying and topological operations must be at the
> geometric level (e.g. click an area to see the attributes using v.what, or
> cleaning operations). When working with PostgreSQL you don't have to care
> about the speed of simple select operations on a single column (like the
> 'cat' column), it will spit out results within milliseconds, even from
> tables with tens of millions of records. So, when an operation which
> requires a simple select on 'cat' takes a lot of time, it must be the part
> 'determining the cat value'.
> However, in the current implementation of some Grass tools it seems to me
> (correct me if I'm wrong) that there are a few operations where the
> database is certainly the limiting factor. The most notable example is
> renaming a large vector table, which is extremely slow. I noticed that
> PostgreSQL is working very hard. Simply renaming the vector dir and perform
> a rename on the table in the database should be sufficient, and adjust the
> contents of vector/<dataset>/dbln file. This should be done in a split
> second, regardless of the size of the table. Doing this manually is much
> much faster than renaming it using g.rename...
> I'm not sure on v.extract, which is also amazingly slow. Maybe it
> regenerates cat id's and must somehow keep the original information linked?
> Kind regards,
> Wouter
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
