[GRASS-dev] wxpython nviz and vdigit compile error + patch
Markus Neteler
neteler at osgeo.org
Sun Jan 4 11:55:52 EST 2009
With gcc 4.3.2 (after Linux upgrade) I get a compile error in both wxpython's
nviz and vdigit:
undefined reference to `std::ios_base::Init::Init[in-charge]()'
Searching around, I found
http://bytes.com/groups/c/158974-compiler-linker-error-undefined-reference-std-ios_base-init-init-charge
Attached diff solves the problem. Any objections to
apply it to trunk?
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090104/a254cc00/makefiles.obj
