[GRASS-dev] wxpython nviz and vdigit compile error + patch
Glynn Clements
glynn at gclements.plus.com
Tue Jan 6 09:48:30 EST 2009
Markus Neteler wrote:
> With gcc 4.3.2 (after Linux upgrade) I get a compile error in both wxpython's
> nviz and vdigit:
> undefined reference to `std::ios_base::Init::Init[in-charge]()'
> Searching around, I found
> http://bytes.com/groups/c/158974-compiler-linker-error-undefined-reference-std-ios_base-init-init-charge
> Attached diff solves the problem. Any objections to
> apply it to trunk?
I dare say that works fine on one particular platform, but really
someone is going to have to figure out how to use distutils to compile
and link the C/C++ portion of a Python package.
