[GRASS-dev] compile error in grass-6.4.0RC1/gui/wxpython
Glynn Clements
glynn at gclements.plus.com
Fri Jan 9 11:18:41 EST 2009
Martin Landa wrote:
> > /usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/vdigit# make
> > /usr/lib/gcc/i586-suse-linux/4.3/../../../../i586-suse-linux/bin/ld: cannot find
> > -lgdi
> > is there a chance to have another solution for this wxpython vdigit problem,
> > than to create a symlink to _gdi_.so shared library? This seems to be quite
> > difficult to solve / implement in a spec file.
> > Maybe someone already has a solution for that?
> currently no, see
> http://trac.osgeo.org/grass/ticket/58
> I still hope reasonable solution will be found before 6.4.0.
The solution is to take the wxPseudoDC code, change the name to avoid
conflicts, then add it to gui/wxpython/vdigit.
If the wxPython developers wanted you to use _gdi_.so as a normal
library, they would have named it libgdi.so.
