[GRASS-dev] error in lib/ogsf/gsd_img_mpeg.c
Hamish hamish_b at yahoo.com
Sun Jan 11 17:09:41 EST 2009
Hi & happy new year everybody,
after svn up, libogsf in develbranch_6 does not build:
gsd_img_mpeg.c: In function 'gsd_close_mpeg':
gsd_img_mpeg.c:439: error: incompatible type for argument 1 of 'url_fclose'
make[2]: *** [OBJ.i686-pc-linux-gnu/gsd_img_mpeg.o] Error 1
make[2]: Leaving directory `/usr/local/src/grass/svn/grass64/lib/ogsf'
seems to be a result of this change:
  http://trac.osgeo.org/grass/changeset/35272
  "Fix bug (pass pointer, not its address) (merge from trunk, r35270)"
system is Debian/etch (aging-stable) on i686.
ffmpeg packages probably from the debian-multimedia repository.
thanks,
Hamish
