[GRASS-dev] gmath and gpde update
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 12 03:46:33 EST 2009
On 11/01/09 22:32, Moritz Lennert wrote:
>>>> Meschach is implemented in C and is able to replace the gmath
>>>> library completely with much better implementations.
>>>> I have integrated meschach into grass for testing purposes and,
>>>> after some very basic testing, it works nicely.
>>>> But im unsure if the licence of meschach is compatible with the GPL?
>>>> Can somebody please verify this? Im not an expert in licensing.
>>> This seems to be the relevant part:
>>> "The source code is available to be perused, used and passed on without
>>> cost, while ensuring that the quality of the software is not
>>> compromised."
>>> There is no mention of modification, and the second half of the
>>> sentence ("while ensuring that the quality of the software is not
>>> compromised") sounds quite suspicious to me. So, without claiming any
>>> expert knowledge either, I would be sceptical.
>> Where did you find that?
> http://www.netlib.org/c/meschach/readme
>> It appears to contradict:
>> http://packages.debian.org/changelogs/pool/main/m/meschach/current/copyright
The Debian version is what's in the copyright file in the source code
available here:
http://www.math.uiowa.edu/~dstewart/meschach/mesch12b.tar.gz
So, sorry for the confusion, no contradiction (just an unclear readme file).
However, is
** Everyone is granted permission to copy, modify and redistribute this
** Meschach Library, provided:
**  3.  No charge is made for this software or works derived from it.
**      This clause shall not be construed as constraining other software
**      distributed on the same medium as this software, nor is a
**      distribution fee considered a charge.
GPL-compatible ?
Moritz
