[GRASS-dev] [GRASS GIS] #429: Add option to disable warnings in
modules
trac at osgeo.org
Mon Jan 12 18:51:42 EST 2009
#429: Add option to disable warnings in modules
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: Unspecified
Cpu: Unspecified |
I would like to be able to suppress warning messages in commands, yet keep
messages based on the GRASS_VERBOSE level, especially in raster projection
(r.proj) where is possible to get thousands of "pj_transform() failed:
tolerance condition error" warnings, depending on the projection, that are
expected but clutter the progress output and slow down the process.
I see that G_warning() has a companion G_suppress_warnings(), so this at
least was an intended possibility at one time (but maybe deprecated or
discouraged now?).
Ticket URL: <http://trac.osgeo.org/grass/ticket/429>
