[GRASS-dev] Re: wxnviz problems compiling develbranch_6 on the Mac
Michael Barton
michael.barton at asu.edu
Tue Jan 13 00:05:29 EST 2009
William,
Your fix worked. Unfortunately, another change broke v.surf.bspline.
Michael
On Jan 12, 2009, at 8:20 PM, William Kyngesburye wrote:
> There were more references to the pixmap field that was removed. I
> cleaned that up for dev6, trunk and release64. (but didn't make it
> into 6.4 RC2)
> On Jan 12, 2009, at 3:54 PM, Martin Landa wrote:
>> 2009/1/12 Michael Barton <michael.barton at asu.edu>:
>>> William Kyngesburye did a fix so that wxnviz would compile on the
>>> Mac.
>>> nviz_cmd wouldn't work on the Mac, but it didn't cause compile
>>> problems.
>>> Something has happened to make this break. Now I once again have
>>> to manually
>>> delete ../lib/nviz/render.c before it will compile.
>> can you send error log?
>> Martin
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly
> what the universe is for and why it is here, it will instantly
> disappear and be replaced by something even more bizarrely
> inexplicable. There is another theory which states that this has
> already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
