[GRASS-dev] Re: [GRASS GIS] #429: Add option to disable warnings in
modules
trac at osgeo.org
Tue Jan 13 18:34:11 EST 2009
#429: Add option to disable warnings in modules
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by glynn):
Replying to [ticket:429 kyngchaos]:
> I would like to be able to suppress warning messages in commands, yet
keep messages based on the GRASS_VERBOSE level, especially in raster
projection (r.proj) where is possible to get thousands of "pj_transform()
failed: tolerance condition error" warnings, depending on the projection,
that are expected but clutter the progress output and slow down the
process.
The correct solution here is as others have suggested: limit the number of
warnings from a single source rather than disabling them completely.
The main problem with pj_do_proj() and pj_do_transform() is that the same
G_warning() call is used to report any and all error conditions from
pj_transform(). Some may be more serious than others, so printing a fixed
number of warnings could result in harmless warnings being shown but more
serious ones being suppressed.
A more robust solution is to record the last error code, and suppress
multiple consecutive occurrences of the same error. If you get a different
error, you generate a warning for it.
This will still produce a flood if you get alternating errors, but
avoiding that is awkward, requiring e.g. an array containing a flag for
each error code.
> I see that G_warning() has a companion G_suppress_warnings(), so this at
least was an intended possibility at one time (but maybe deprecated or
discouraged now?).
It's a band-aid for library functions which generate too many warnings. I
suggest removing it in 7.0. If there are cases where the library should
normally produce a warning (because it's unrealistic to require
programmers to manually check for rare errors) but cases where it needs to
be disabled, there should either be a "nowarn" flag or a corresponding
function to suppress a specific warning.
The existing usage means that code which uses G_suppress_warnings() around
e.g. G_read_colors() to suppress the "colour support ... missing" warning
(which is harmless; you just get the default rainbow colour table) could
also suppress more significant warnings.
Ticket URL: <http://trac.osgeo.org/grass/ticket/429#comment:7>
