[GRASS-dev] 64 bit compiling of GRASS 7 on Mac - /lib/vector/diglib
fails
Michael Barton
michael.barton at asu.edu
Tue Jan 13 22:34:09 EST 2009
I tried again to compile GRASSS 7 in 64 bit mode on the Mac. Thanks to
various fixes of the past few weeks, I had only one error and was able
to make a functioning app. Here is the error. If it can be fixed, then
we can run GRASS in 64 bit on the Mac (without nviz of course).
Finished compilation: Tue Jan 13 18:15:15 MST 2009
make: *** [default] Error 1
cmb-MBP-2:grass7_src cmbarton$ cd /Users/cmbarton/grass_dev/grass7_src/
lib/vector/diglib
cmb-MBP-2:diglib cmbarton$ make
if [ "" != "" -a -f "".html ] ; then make html ; fi
make OBJ.i386-apple-darwin9.6.0/test
echo "==============TEST============="
gcc -L/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.6.0/
lib -arch i386 -arch i386 -Os -arch i386 -arch i386 -Os -arch i386
-arch x86_64 -Os -I/Library/Frameworks/GDAL.framework/Versions/1.6/
Headers -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/test test.c -
lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -
lgrass_rtree \
-lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lz
ld warning: in /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
darwin9.6.0/lib/libgrass_dig2.dylib, file is not of required
architecture
darwin9.6.0/lib/libgrass_gis.dylib, file is not of required architecture
darwin9.6.0/lib/libgrass_datetime.dylib, file is not of required
architecture
darwin9.6.0/lib/libgrass_rtree.dylib, file is not of required
architecture
Undefined symbols for architecture x86_64:
"_dig_fflush", referenced from:
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
"_dig_set_cur_port", referenced from:
_main in ccA94H4H.o
"_dig__fread_port_C", referenced from:
_main in ccA94H4H.o
"_dig__fread_port_D", referenced from:
_main in ccA94H4H.o
"_dig__fread_port_F", referenced from:
_main in ccA94H4H.o
"_dig__fread_port_I", referenced from:
_main in ccA94H4H.o
"_dig__fread_port_L", referenced from:
_main in ccA94H4H.o
"_dig__fread_port_S", referenced from:
_main in ccA94H4H.o
"_dig_fseek", referenced from:
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
_main in ccA94H4H.o
"_dig__fwrite_port_C", referenced from:
_main in ccA94H4H.o
"_dig__fwrite_port_D", referenced from:
_main in ccA94H4H.o
"_dig__fwrite_port_F", referenced from:
_main in ccA94H4H.o
"_dig__fwrite_port_I", referenced from:
_main in ccA94H4H.o
"_dig__fwrite_port_L", referenced from:
_main in ccA94H4H.o
"_dig__fwrite_port_S", referenced from:
_main in ccA94H4H.o
"_dig_init_portable", referenced from:
_main in ccA94H4H.o
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
lipo: can't open input file: /var/folders/AK/AKpYwDw1EoWI+fFF02nvRk++
+TI/-Tmp-//ccnRDjhL.out (No such file or directory)
make[1]: *** [OBJ.i386-apple-darwin9.6.0/test] Error 1
make: *** [default] Error 2
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090113/3d6b198f/attachment-0001.html
