[GRASS-dev] 64 bit compiling of GRASS 7 on Mac -
/lib/vector/diglib fails
Michael Barton
michael.barton at asu.edu
Wed Jan 14 12:31:11 EST 2009
On Jan 14, 2009, at 6:35 AM, <grass-dev-request at lists.osgeo.org> wrote:
> Date: Tue, 13 Jan 2009 22:55:47 -0600
> From: William Kyngesburye <woklist at kyngchaos.com>
> Subject: Re: [GRASS-dev] 64 bit compiling of GRASS 7 on Mac -
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass developers <grass-dev at lists.osgeo.org>
> Message-ID: <12C25FC2-2E73-49B7-A10D-1098EBAFB329 at kyngchaos.com>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> On Jan 13, 2009, at 9:34 PM, Michael Barton wrote:
>> gcc -L/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
>> darwin9.6.0/lib -arch i386 -arch i386 -Os -arch i386 -arch i386 -
>> Os -arch i386 -arch x86_64 -Os -
> Ah, here could be the problem - either your CFLAGS or LDFLAGS export
> has 2 i386 flags, missing x86_64.
You were right William. It compiled with a complaint only from xganim.
However, you were also right in that in spite of compiling, stuff
doesn't work well. Too bad that we can't compile 64 bit on the Mac. :(
Michael
