[GRASS-dev] 64 bit compiling of GRASS 7 on Mac - /lib/vector/diglib fails
Markus Metz markus.metz.giswork at googlemail.com
Wed Jan 14 13:08:51 EST 2009
William Kyngesburye wrote:
> On Jan 14, 2009, at 11:31 AM, Michael Barton wrote:
>> You were right William. It compiled with a complaint only from
>> xganim. However, you were also right in that in spite of compiling,
>> stuff doesn't work well. Too bad that we can't compile 64 bit on the
>> Mac. :(
>> Michael
> yeah, just tried 64bit v.in.ogr in trunk, and it still crashes. I
> (finally) submitted a bug report to get the ball rolling to fix it.
Not that I know anything about compiling on Mac, but was gdal compiled
with -arch i386 or -arch x86_64? Just an idea, GRASS links against gdal
and ogr libraries, and if they were compiled for a different
architecture (i386 instead of x86_64), it won't work.
Markus M
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
