[GRASS-dev] Re: problem with gdal 1.6 framework
William Kyngesburye woklist at kyngchaos.com
Wed Jan 14 23:32:16 EST 2009
Which version of the framework?  It should be good in 1.6.0-3.
On Jan 14, 2009, at 9:17 PM, Michael Barton wrote:
> William,
> The gdal 1.6 framework has a postgreSQL dependency that makes it
> fail when doing any kind of translation, like saving the display.
> Error:
> Could not create PNG: dyld: Library not loaded: /usr/local/pgsql/lib/
> libpq.5.dylib
> Referenced from /Library/Frameworks/GDAL.framework/Versions/1.6/unix/
> bin/gdal_translate
> Reason: image not found
> (the last error is a TclTk error because gdal_translate doesn't work)
> Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
