[GRASS-dev] grass7 compile problems
Helena Mitasova
hmitaso at unity.ncsu.edu
Thu Jan 15 15:02:02 EST 2009
I am trying to get to test the new r.watershed but I am stuck at
compiling grass7
(I had it working OK without wxwidgets before I updated)
First, the issue with wxWidgets, when I include --with-wxwidgets
I get
checking whether to use wxWidgets... yes
checking for wx-config... /usr/bin/wx-config
checking wxWidgets version... 2.8.9
checking for wx/wxprec.h... yes
checking for wx/wxPython/pseudodc.h... no
configure: error: *** Unable to locate wxWidgets includes.
but I do have it
deliboz%
ls /usr/lib/wxPython-2.8.7.1-gtk2-unicode/include/wx-2.8/wx/wxPython
i_files printfw.h pseudodc.h pyclasses.h pydrawxxx.h pyistream.h
pytree.h swigver.h twoitem.h wxPython.h wxPython_int.h
I tried to add (I don't know what I am doing here)
--with-wxwidgets-includes=/usr/lib/wxPython-2.8.7.1-gtk2-unicode/include/wx-2.8/wx
--with-wxwidgets-libs=/usr/lib/wxPython-2.8.7.1-gtk2-unicode/include/wx-2.8/wx/wxPython
but I got the same as above
To get at least something running
I did make distclean
svn update
configure, make, make install
with skipped wxWidgets, configure goes through
but make gives error for g.cairocomp (do I need it compiled?)
OBJ.x86_64-unknown-linux-gnu/main.o: In function `init_xlib':
/local/home/helena/grasssvn/grass_trunk/general/g.cairocomp/main.c:118:
undefined reference to `cairo_xlib_surface_get_xrender_format'
collect2: ld returned 1 exit status
and when I try to run any r.* command I get
"ERROR: Incompatible library version for module"
g., v. commands run OK
any advice would be appreciated,
Helena
-----configure without wxwidgets-----------------------
GRASS is now configured for: x86_64-unknown-linux-gnu
Source directory: /local/home/helena/grasssvn/grass_trunk
Build directory: /local/home/helena/grasssvn/grass_trunk
Installation directory: ${prefix}/grass-7.0.svn
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -Wall
C++ compiler: c++ -g -O2
Building shared libraries: yes
64bit support: yes
OpenGL platform: X11
MacOSX application: no
NVIZ: yes
BLAS support: no
C++ support: yes
Cairo support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
JPEG support: yes
LAPACK support: no
Large File support (LFS): yes
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: no
Python support: yes
Readline support: no
SQLite support: yes
Tcl/Tk support: yes
wxWidgets support: no
TIFF support: yes
X11 support: yes
Regex support: yes
POSIX thread support: no
On Wed, 2009-01-07 at 00:44 +0000, Glynn Clements wrote:
> Helena Mitasova wrote:
> > I am trying to get myself up to date on grass7, especially look at the
> > wxnviz but although I did make distclean and updated grass trunk
> > grass7_wxnviz is not found - am I perhaps missing
> > something in my configure (see below)?
> You need --with-wxwidgets for the vdigit and nviz add-ons to the wx
> GUI, also for the xganim replacement.
> Also, --with-motif no longer exists.
