[GRASS-dev] grass7 compile problems
Markus Neteler neteler at osgeo.org
Thu Jan 15 19:15:20 EST 2009
On Thu, Jan 15, 2009 at 10:20 PM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> I forgot, if gdal is compiled with grass support based on a previous
> version, that doesn't work too, you have to compile gdal without grass
> support again, then grass7 with gdal support. It's a bit of a hassle but
> worth the effort, grass7 is really nice:-)
Won't the GRASS-GDAL plugin solve this? Then you avoid this nightmare...
Markus
