[GRASS-dev] Re: [GRASS GIS] #58: wx version of v.digit relies upon non-portable hacks
GRASS GIS trac at osgeo.org
Fri Jan 16 17:21:39 EST 2009
  Reporter:  marisn       |       Owner:  martinl
      Type:  defect       |      Status:  assigned
  Priority:  critical     |   Milestone:  6.4.0
 Component:  default      |     Version:  6.3.0 RCs
Resolution:               |    Keywords:  wxGUI, v.digit
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by kyngchaos):
 Those are definitely not needed for OSX, so they should be conditionally
 compiled, even if this is a temporary solution.  The current method of
 "-bundle -undefined dynamic_lookup" for OSX is the proper way to handle
 python extensions in general, which coincidentally takes care of the GDI
 problem.
 So, a wildcard couldn't be used for SOURCES.  Something like:
 SOURCES := cats.cpp digit.cpp driver_draw.cpp driver.cpp \
         line.cpp message.cpp select.cpp undo.cpp vertex.cpp \
         $(LIB_NAME)_wrap.cpp
 ifneq ($(findstring darwin,$(ARCH)),darwin)
 SOURCES = pseudodc.cpp $(SOURCES)
 endif
Ticket URL: <http://trac.osgeo.org/grass/ticket/58#comment:12>
