[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating
error for 2nd order transformation
Michael Barton
michael.barton at asu.edu
Fri Jan 16 18:02:13 EST 2009
I don't remember reopening it, but don't think it was ever "fixed".
There was some discussion about whether this is a "bug" or not. As I
remember it, here is what happens. If you select 6 points for a 2nd
order transform, you get 00's or bogus numbers for the RMA
calculations. I think someone pointed out that because 6 is a minimum
number, you should get 0's. This seems weird and not too useful. Also,
at least a couple of people in my lab ended up with blank maps with
exactly 6 points. If you use 7 or more points, all problems go away.
I took this to mean that what the docs *really* mean is that you must
have *more* than 6 points for a 2nd order transformation. I changed
the GUI accordingly and suggested that the docs be changed. Others
have said that, no, you need *at least* 6 points, not more than 6
points.
I have not retested this, but AFAIK, there was no change to g.transform.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jan 16, 2009, at 3:29 PM, GRASS GIS wrote:
> #163: g.transform no longer calculating error for 2nd order
> transformation
> Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: reopened
> Priority: major | Milestone: 6.4.0
> Component: default | Version: svn-develbranch6
> Resolution: | Keywords: g.transform georectify
> Platform: All | Cpu: Unspecified
> Comment (by martinl):
> Any reason why this ticket is still open?
> Ticket URL: <http://trac.osgeo.org/grass/ticket/163#comment:10>
> GRASS GIS <http://grass.osgeo.org>
