[GRASS-dev] Re: grass-dev Digest, Vol 33, Issue 37
Markus Metz
markus.metz.giswork at googlemail.com
Sat Jan 17 05:21:15 EST 2009
Helena Mitasova wrote:
> On Jan 17, 2009, at 12:07 AM, Michael Barton wrote:
>> Markus,
>> I compiled last night and was able to try this on my Mac this
>> evening. No problem at all with the North Carolina elev_lid792_1m
>> DEM. Everything ran very fast, of course--even though it runs at
>> 32bit on the Mac.
>> As expected, the MFD results look much more realistic than the SFD
>> results. Much less linearity and more sinuosity. I can post the
>> displays if anyone wants to see them.
>> No errors from the command.
>> No errors in compiling.
>> Seems to work fine on the Mac.
>> I'm not sure why this can't be backported to develbranch_6 since
>> 6.4RCx is already out. Does it change any of the r.watershed
>> arguments or behavior using the pre-MFD arguments?
Yes, MFD is default, so using the same arguments produces different
results. See also my reply to Helena:
http://lists.osgeo.org/pipermail/grass-dev/2009-January/041965.html
I would prefer to stay out of the discussion about backporting and leave
this decision to the long-time developers.
> Michael
> - it needs to be thoroughly tested on wide range of data
> before replacing it. I am trying to get to it too and Markus M has
> done already quite a bit of testing himself. If you can ask Isaac
> and/or whoever has grass7 and is around to test it with different data
> (wide range of resolutions, data sources, combinations of parameters,
> integer or float DEMs, latlong, different size and type of depressions
> etc.) that would help.
I fully agree. BTW (repeating myself), the results improve a lot if
float DEMs are multiplied with 100 or 1000 before used as input.
Markus M
