[GRASS-dev] Re: [GRASS GIS] #58: wx version of v.digit relies upon non-portable hacks
GRASS GIS trac at osgeo.org
Sat Jan 17 05:54:50 EST 2009
  Reporter:  marisn       |       Owner:  martinl
      Type:  defect       |      Status:  assigned
  Priority:  critical     |   Milestone:  6.4.0
 Component:  default      |     Version:  6.3.0 RCs
Resolution:               |    Keywords:  wxGUI, v.digit
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:12 kyngchaos]:
 > Those are definitely not needed for OSX, so they should be conditionally
 compiled, even if this is a temporary solution.  The current method of
 "-bundle -undefined dynamic_lookup" for OSX is the proper way to handle
 python extensions in general, which coincidentally takes care of the GDI
 problem.
 That's right, but compiling against local copy of pseudodc should work
 also on Mac and should be harmless. Just to avoid other platform dependent
 conditionalization.
Ticket URL: <http://trac.osgeo.org/grass/ticket/58#comment:13>
