[GRASS-dev] [GRASS GIS] #445: grass_nviz.LoadSurface not returning id when called a 2nd time
GRASS GIS trac at osgeo.org
Mon Jan 19 18:22:56 EST 2009
 Reporter:  cmbarton   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.0
Component:  wxGUI      |     Version:  svn-develbranch6
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 This item may fix a number of things.
 If you start wxnviz and display a map, close wxnviz, restart nviz...
 The 2nd time you start wxnnviz...
 id = self.nvizClass.LoadSurface(str(layer.name), None, None)
 in nviz_mapdisplay.py is not returning the id of the map. It returns only
 -1. It's got the name right in both cases. But it returns an id value the
 first time it is run, but not subsequently.
 This is at line 477 of nviz_mapdisp.py. I'm not sure, but it looks like a
 SWIG call in grass_nviz.py.
 Because this does not return an id value, a lot of other things begin to
 bomb.
Ticket URL: <http://trac.osgeo.org/grass/ticket/445>
